Hard Drive upgrade concern
Solved by Chionele,
Since your OS is on another drive you just need to take out the HDD and plug in the new one. Then you'll probably want to transfer your data with USB dock / cable to the new drive.
kisserik93 ·
Posted in Peripherals4 -
Rick13 ·
Posted in CPUs, Motherboards, and Memory11 -
6
popularlion ·
Posted in Troubleshooting5 -
2
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1
