7 minutes ago, help me pls.. said:
is there anyone who can help me? i wanted to view an fb profile in full resolution using fb id.
thanks in advance
https://www.facebook.com/profile.php?id=IDNUMBERHERE
If you're talking about viewing the profile without using Facebook? Can't help you there. It's probably not possible as you would need to interact with their api, which they almost certainly won't want you doing.
CPU: i7 4790k, RAM: 16GB DDR3, GPU: GTX 1060 6GB
https://linustechtips.com/topic/1265970-need-help-mates/#findComment-14186097
i can use facebook its just that I cant view the profile picture in full resolution because its private, thanks for the help btw
https://linustechtips.com/topic/1265970-need-help-mates/#findComment-14186116
Yeah there's nothing you can do about that. Facebook's privacy is bad, but not that bad. If they've set their profile as private, you won't be able to see that picture at full-res without becoming friends with them.
https://linustechtips.com/topic/1265970-need-help-mates/#findComment-14186132
thanks for helping
https://linustechtips.com/topic/1265970-need-help-mates/#findComment-14186139
