Did the things you need to install an AIO to an intel board changed over the years? Is the bracket for a 4th gen same with a 10th gen?
  • CPU Intel i5-4570 3.2GHz base 3.6GHz Turbo
  • Motherboard Asus B85-Pro Gamer ATX
  • RAM Avexir Core Red 2x4GB DDR3 1600Mhz
  • GPU EVGA GTX 750 SC
  • Case Deepcool Dukase V.2
  • Storage 1TB Seagate Barracuda 7200rpm
  • PSU Aerocool KCAS700w 80+ Bronze
  • Display VX239H 24" Frameless IPS
  • Cooling Deepcool Dukase V.2
  • Keyboard Asus Cerberus Gaming Keyboard
  • Mouse A4Tech Bloody v5
  • Sound A4Tech G501 7.1/360degree Headset
  • Operating System Windows 10 Pro
https://linustechtips.com/topic/1265834-aio-cooling-brackets/
Yes-ish.
Intel consumer 4th and 10th gen? That's LGA 1150 and LGA 1200 respectively, those use the same spacing for cooler mounting, meaning you can use the same brackets.
Intel HEDT (high-end desktop) 4th and 10th gen? Those are LGA 2011 and 2066, which are not the same.
https://linustechtips.com/topic/1265834-aio-cooling-brackets/#findComment-14184892
Just now, minibois said:
Yes-ish.
Wellllllllllllll I'mmore on the not high-end of the spectrum soooooooooooooo HAHAH thanks.
https://linustechtips.com/topic/1265834-aio-cooling-brackets/#findComment-14184897
1 minute ago, minibois said:
Yes-ish.
Quick question though, should I change to an AM4 motherboard, can you provide a link to a replacement part for my current ones?
https://linustechtips.com/topic/1265834-aio-cooling-brackets/#findComment-14184900
It's much more likely you're asking about 'consumer' CPU platforms, which are LGA 1150 and LGA 1200, which indeed do use the same spacing.
If you want to be 100% sure what socket your CPU's use, look up "CPUName ARK", CPUName being the name of your CPU and ARK being Intel's website for specifications. Check for "FCLGA" there, which are probably LGA 1150 for the 4th gen and LGA 1200 for the 10th gen.
Depends on the cooler your use.
You probably need to get a replacement bracket for the cooler if you go for AM4 and want to re-use your cooler.
https://linustechtips.com/topic/1265834-aio-cooling-brackets/#findComment-14184910
Thank you for the insight. I'm using the older version of the Captain 240 and I would like to keep using it. It has been keeping my CPU cool for some years but it hasn't lost its touch xD
https://linustechtips.com/topic/1265834-aio-cooling-brackets/#findComment-14185108
