6 minutes ago, RTX 2070 Max-Q said:
Breh xd
Just imagine, a bose einstein condensate quantum gas cloud with instantaneous heat transfer cooling your components so much that they effectively become superconductors. Count me in fam! 100k res gaming here we come!
https://linustechtips.com/topic/1265754-laser-cooling-a-pc/#findComment-14184375
What about sub-kelvin man, your far behind
https://linustechtips.com/topic/1265754-laser-cooling-a-pc/#findComment-14184377
11 minutes ago, Nanook said:
Forget sub-ambient, lets push our way towards near 0 kelvin.
As per the luminol thread, this is fantasy physics for non-molecular scale applications. Is there a point to this thread? Are you suggesting a potential method for application (with any kind of practicality in mind)
https://linustechtips.com/topic/1265754-laser-cooling-a-pc/#findComment-14184384
https://linustechtips.com/topic/1265754-laser-cooling-a-pc/#findComment-14184392
3 minutes ago, Ankh tech tips said:
I think dark matter is subkelvin
5 minutes ago, Ankh tech tips said:
well you go it all wrong in sence of temperature nothing can go below absolute zero and dark matter is a completlely unknow suff
if it was useful give it a like :) btw if your into linux pay a visit here
https://linustechtips.com/topic/1265754-laser-cooling-a-pc/#findComment-14184405
Just now, mahyar said:
well you go it all wrong in sence of tempurture nothing can go below absolute zero and dark matter is a completlely unknow suff
Well, now wer eached it and it acts against gravity, I can get you more websites
https://linustechtips.com/topic/1265754-laser-cooling-a-pc/#findComment-14184411
these things are more of a theory in pratice these are untested so there is no real proof to them
https://linustechtips.com/topic/1265754-laser-cooling-a-pc/#findComment-14184418
7 minutes ago, Ankh tech tips said:
no, whe reach sub-negative nanokelvins look it up
I should probably phrase that a little more carefully. Realistically it is not possible to reach zero kelvin. However, there have been some problems and proofs that hypothesize what happens if you go below zero kelvin. Again oddly things tend towards much hotter temperatures below zero kelvin. Which is pretty counter intuitive. I wish I could find the example and share it.
https://linustechtips.com/topic/1265754-laser-cooling-a-pc/#findComment-14184420
They did reach it, they cooled a potassium atom to sub kelvin temps, did you read the websites?
https://linustechtips.com/topic/1265754-laser-cooling-a-pc/#findComment-14184424
@Nanook, this thread currently does not meet our minimum requirements for threads. This means that it lacks context, and since you are suggesting theoretical solution, sources that back it up. Like where your picture is from for example.
Posting just link, picture or video without context is seen as pointless and threads are subject for locking as such.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1265754-laser-cooling-a-pc/#findComment-14184427
i did and
Quote
It is important to note that the negative temperature region, with more of the atoms in the higher allowed energy state, is actually warmer than the positive temperature region. If this system were to be brought into contact with a system containing more atoms in a lower energy state (positive temperatures) heat would flow from the system with the negative temperatures to the system with the positive temperatures. So negative temperatures are warmer! And all this has to do with the how we define temperature.
https://linustechtips.com/topic/1265754-laser-cooling-a-pc/#findComment-14184428
1 minute ago, mahyar said:
btw did you actually read them or just pasted links?
did you read them
"Physicists at the Ludwig-Maximilians University Munich and the Max Planck Institute of Quantum Optics in Garching have now created an atomic gas in the laboratory that nonetheless has negative Kelvin values. These negative absolute temperatures have several apparently absurd consequences: although the atoms in the gas attract each other and give rise to a negative pressure, the gas does not collapse – a behaviour that is also postulated for dark energy in cosmology"
https://linustechtips.com/topic/1265754-laser-cooling-a-pc/#findComment-14184430
6 minutes ago, Ankh tech tips said:
did you read them
"Scientists have cooled potassium gas to one billionth of a degree below absolute zero. But in the quantum world, that's actually hotter than the Sun. It's hotter, even, than infinity degrees Kelvin. Vladan Vuletić, a quantum physicist at MIT, talks about this 'Bizarro World' temperature."
https://www.npr.org/2013/01/04/168624854/negative-temperatures-that-are-hotter-than-the-sun
"A substance with a negative temperature is not colder than absolute zero, but rather it is hotter than infinite temperature."
https://en.wikipedia.org/wiki/Negative_temperature
Ha! Found it!. But I had it kinda wrong. Hotter than infinite kelvin is negative kelvin.
https://linustechtips.com/topic/1265754-laser-cooling-a-pc/#findComment-14184440
Yeah, so basically, infinite negative pressure, infinite temperature, and quantum physics allows it to be at two places in the same time
https://linustechtips.com/topic/1265754-laser-cooling-a-pc/#findComment-14184446
Guest
