GTX 1070 + Samsung 980 Pro on a B550
Solved by -rascal-,
12 minutes ago, veimiK said:Hey!
I've got a quick theoretical question regarding PCIe Gen 4. I've got a GTX1070 and I want to get a 980 PRO in the M.2 slot. Is it possible for both of them to work at a full speed simultaneously? Motherboard is a Gigabyte B550 AORUS PRO.
If you use the top M.2 slot, it will use the extra PCI-E 4.0 lanes supplied by the CPU.
You GPU + M.2 SSD will run with PCI-E 4.0 full speed.
If you use the bottom M.2 slot, it be come from the B550 chipset.
That will run at PCI-E 3.0 speed.
