Hi guys,
I have a pretty serious problem, today I got home from work and my pc would not boot
So I tried to refresh with then win8 64bit disk...which didn't work, it displayed that the storage media was locked...so I tried to do a fresh install of win 8 again but every time I try it finishes installing but crashes straight after which sends it into a loop of trying to diagnosis and atempt repair.....then blue screen which displays an error I can not read.
Pc specs are
Intel 3930k cpu
Asus rampage 4 extreme mobo
16gb gskill 1333mhz ram
Sandisk ultra plus 120gb ssd
500gb 7200rpm hdd
1tb 7200rpm hdd
Seagate 1200w psu
Sapphire hd 6950
Gigabyte hd 6970
Any help would be greatly appreciated :)
https://linustechtips.com/topic/126553-pc-will-not-boot/
Hi guys,
Pc specs are
Intel 3930k cpu
500gb 7200rpm hdd
1tb 7200rpm hdd
Seagate 1200w psu
Sapphire hd 6950
Gigabyte hd 6970
Test with one video card at a time, try out each stick of ram etc.
https://linustechtips.com/topic/126553-pc-will-not-boot/#findComment-1683203
Sapphire hd 6950
Gigabyte hd 6970
Try one card and tell us if it works because wut... Unless you turned your 6950 into a 6970, I don't know if that would be a great idea to run these at the same time, but someone may correct me here if I'm wrong.
VIDEO GAMES                                  Max Power Build Log
https://linustechtips.com/topic/126553-pc-will-not-boot/#findComment-1683217
It works, so there's no problem there really.
https://linustechtips.com/topic/126553-pc-will-not-boot/#findComment-1683358
