Hey guys this is my first build, prolly a little overboard, but I got a nice tax return this year so whatever, plus I want a beast for Star Citizen.  This is my first for everything.  I am going to use the 4-way optimization to slightly overclock the cpu, pretty scared and intimidated by the manual overclocking guide here.  Much less nervous for the build itself.
Specs:
CPU: Intel 4770k
Cooler: Corsair h100i
Mobo: Asus Maximus VI Formula
Ram: 16gb (2x8) Corsair Dominator Platinum Clocked 2133
GPU:  Asus Direct CU II 780ti
SSD:  Samsung 840 Evo 250gb
HDD: 1tb Seagate Barracuda
PSU:  Corsair AX 760 80+ Plat
Case: Corsair 750d
Only got package 1 of 3 today so far....pretty bummed wanted to build this thing before work started.  Also, based on tracking info I wont be getting the third package until tomorrow
post-43828-0-78172300-1394639067_thumb.j
https://linustechtips.com/topic/126535-my-first-build/
Cool. I wanna see this bad boy.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/126535-my-first-build/#findComment-1682953
Wow. Beast, dude. Can't wait to see how it all looks with that color theme in that 750D.
LTT Recruit: Tacoma | Organization: UOLTT Conglomerate | Group: Salvage and Military | Fleet: Anvil Carrack, Aegis Retaliator and CO Mustang Omega
Appreciation to: artofinca.com | UOLTT Conglomerate on RSI and LTT
If you don't know what my avatar is, it's from: Silverhawks
https://linustechtips.com/topic/126535-my-first-build/#findComment-1683648
Good choice of parts!
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/126535-my-first-build/#findComment-1683661
Awesomew! Might do a build log with my formula too :D
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
https://linustechtips.com/topic/126535-my-first-build/#findComment-1683666
thy guys
@DamDirtyApe I am still not sure what I am going to do with colors lol I have the options to go white or red...maybe both?  No LEDs yet wanna see what it looks like without
Don't go with colored LED's. Do a red themed build, but stick with white LED's. Looks a lot better imo. :)
Main Rig
Phone
https://linustechtips.com/topic/126535-my-first-build/#findComment-1684079
just fyi, the 4-way optimization doesn't work on the formula board the way all the asus vids show.  it just has 3 presets (4.2, 4.4, 4.6 iirc), with preset locked voltages and everything.  nothing is actually optimized for your setup like all the asus fluff marketing material says for any of the z87 ROG boards.  that feature only works on their mainstream boards (the gold ones)
HP something | 5600X | Corsair  16GB | Zotac ArcticStorm GTX 1080 Ti
CaseLabs SM8 | EK Supremacy | UT60 420 | ST30 360 | ST30 240
Gentle Typhoon's and Noctua's and Noiseblocker eLoop's
https://linustechtips.com/topic/126535-my-first-build/#findComment-1684270
I am aware, i was going to just overclock minimally to 4.2, do you think I would come into any issues with voltage?  What about overclocking ram speed?
https://linustechtips.com/topic/126535-my-first-build/#findComment-1684369
I'd follow this guide if I were you (and I did) for overclocking instead of using the asus preset.  It covers ram overclocking also
http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
https://linustechtips.com/topic/126535-my-first-build/#findComment-1684473
the OP of that thread still responds to it.  if you have any questions just post in there.
https://linustechtips.com/topic/126535-my-first-build/#findComment-1684763
OK, it took forever and I had to RMA my HDD, was pretty frustrated with all that, but the build is complete and here are some pics!
Started swapping out the fans for the AF140s and the SP120's on the H100i
post-43828-0-43833100-1394999228_thumb.j
Next I put in the the PSU and the SSD just to get an idea of what kind of cable management I needed (which I will not be showing you!)
post-43828-0-04116100-1394999284_thumb.j
Then Mobo Ram and the cooler!
post-43828-0-19965100-1394999381_thumb.j
Then the last two are the final build pics (minus my HDD =( )
post-43828-0-59444400-1394999515_thumb.j
post-43828-0-65902600-1394999523_thumb.j
Not sure why everything is sideways, but you get the idea of the looks which I did not plan on going black and red at first I wanted black and white, but that mobo is so sexy
https://linustechtips.com/topic/126535-my-first-build/#findComment-1705225
