Original Xbox on 4:3 monitor?
Ali_H.
So I'm trying to use my original Xbox with a Westinghouse LCM-15V5 but it keeps saying out of range. Is there a fix for this. I tried changing the refresh rate from 75hz to 60hz but that didn't do anything. I'll send a photo of the screen if it helps
Are you using some type of video adapter or are you using the AV cable that comes with the Xbox?
SPEC LIST:
CPU: AMD Ryzen 5 2600x w/ AMD Wraith Stock Cooler
MOTHERBOARD: Asus ROG Strix B-450F
RAM: Corsair Vengeance Pro RGB 32gb 3200mhz (2x16gb)
GPU: Nvidia RTX 2080 Super FE
PSU: Corsair 750x 80plus Gold
FANS: Dual Corsair LL Series LL140mm Dual Light Loop RGB
MONITORS: BenQ ZOWIE XL2411P 24 Inch FHD LED 144Hz (DP)
Lenovo - G25-10 24.5" LED FHD 144HZ Monitor (HDMI)
PATIENCE: NOT CURRENTLY INSTALLED
P.S: STILL REALLY WANTING TO FIND SOMEONE WHO CAN CARRY ME TO GRAND CHAMPION IN ROCKET LEAGUE :)
P.P.S: I NO LONGER NEED TO BE CARRIED TO GRAND CHAMPION AS I HAVE MADE IT ON MY OWN 😁
I'm using an adapter because the monitor only has dvi and VGA (it's an old monitor).
Maybe the Xbox isn't compatible with an adapter like that. If you happen to have some type of TV or anything else around you it would be best to check and see if the Xbox is outputting video or not. If it isn't the Xbox might have just succumb to its age.
SPEC LIST:
Yeah, it might be the adapter because I know the Xbox works.
Keep in mind that if you're using any form of adapter that doesn't do any form of deinterlacing, it's outputting 720x480i (or 720x576i, if you're using a PAL console).
If what you do have can deinterlace a 480i/576i signal, your monitor most likely should work with it fine.
