so I have a old dell inspiron 620 with a i5-2320 2x4gb ddr3 patriot Viper
480watt pcu 1tb pny ssd
the old graphics card i had in this was a geforce gtx 460 v2 1gb
ran fine in the system then I swapped that for a R9 270x windforce 2gb and went to power on and...
lights on
fans on "including gpu fans constantly"
but no signal to monitor
I have no idea what the issue is here
the pci express slot is a 2.1
https://linustechtips.com/topic/1264179-i-need-some-help/
Did you uninstall the drivers for the old GPU before you swapped it out? If you put the old GPU back in does the PC work fine?
I mostly speak from my own past experience from similar problems. My solution may not work for you, but I'll always try my best to help as much as I can. If you want me to see your reply, make sure to quote my comment or mention me @WaggishOhio383, and I'll get back to you as soon as possible.
-- My PC Build --
Ryzen 7 2700x
AsRock B450 Steel Legend
XFX RX 590 Fatboy
Crucial Ballistix Tactical Tracer RGB 16GB 3200MHz
120GB Crucial BX500 SSD + 2TB Seagate Barracuda HDD
Corsair CX650M
Phanteks Eclipse P350x
https://linustechtips.com/topic/1264179-i-need-some-help/#findComment-14171621
Sometimes these older workstations are not compatible with certain RADEON/RX graphics cards. I had an old lenovo mechine that lenovo hade made so the bios would straight out not see radeon/rx cards and was only validated for geforce cards below the 20 series. That might be whats going on here but I cant be sure.
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
https://linustechtips.com/topic/1264179-i-need-some-help/#findComment-14171650
