i have cm mwe 750 gold fully modular power supply. when i turn on the computer only rgb lights turn on, no cpu cooler or case fan starts. the power supply makes a silent sound while its fan also does not run. it happened in the past few times when i hold the power button for long. yesterday the issue started more frequently when i turned off the pc by holding the power button for long(only few seconds until the pc shuts down completely. i want to know if my power is faulty or my motherboard is doing this issue.
https://linustechtips.com/topic/1264036-power-supply-not-working-properly/
Post picture of the inside of the case.
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
469881689_WhatsAppImage2020-11-01at10_46.28PM(1).thumb.jpeg.ae8be70175cc1627ea7bb7b901efb3bf.jpeg1726185196_WhatsAppImage2020-11-01at10_46_29PM.thumb.jpeg.7f393de6366535144107c7207402a951.jpeg368244806_WhatsAppImage2020-11-01at10_46_28PM.thumb.jpeg.e5dcd7fd8ce364894baf8796dce1a200.jpeg
43 minutes ago, jonnyGURU said:
Motherboard issue.
if it would be a motherboard issue then the fan of power supply should be running but the power supply is making a very silent sound of current pasiing through it when rgb lights turn on and the pc don't
2 hours ago, alihaider741 said:
if i wait for 20-30 minutes and then push the power button the pc starts
That's a heat issue...
Leave the side off the case.
Does it do the same thing?
No.  Incorrect.
PSU is "always live" with +5VSB.  It's going to feed that power to the motherboard no matter what.  It's not going to fully turn on the rest of the way until the motherboard "tells it".
56 minutes ago, jonnyGURU said:
No.  Incorrect.
how can i assure that its motherboard issue. actually its in warranty so i can claim it
1 minute ago, alihaider741 said:
@Ankerson
i pulled the psu from the case and kept is outside and then started the pc. the issue is not resolved so i think its not a heat issue.
is there any method to ensure that my mobo is doing the problem or psu
Likely a MB issue then.
Normally when it won't work then after a period of time it starts working again it's a heat problem.
Could be either the PSU or the MB's VRMS got too hot and had to cool back down.
its a psu issue i directed the psu and the fan did not spin this time.
i don't have the invoice as it is a gift. can i claim it on the basis of its manufacturing date that is 2019?
it is in warranty period according to cm site.
@Ankerson
