SCCM Help..
Go to solution Solved by Sir Asvald,
25 minutes ago, leadeater said:
Is there no entry in the log that contains "Client boot action reply"?
Got it working! restarted the server! :D
Hello all.
Heads up, I am new to this, please be patient with me! :P :D
I have setup our new SCCM 2019 server today and I am having some problems with the PXE Boot. The VM boots up, I hit 12 and then I get "Preparing network connections" and the it closes. Nothing happens then it restarts. I have set everything up, I published everything to the distribution points and I even imported the drivers for VMware and my laptop Realtek drivers..
Any help please?
https://linustechtips.com/topic/1263794-sccm-help/
I suspect when you're creating the VM you are using VMXNET3 NIC type, you need in inject the VMware Tools network driver in to the WinPE image otherwise when it boots in to WinPE it will fail the network prep and reboot like you are getting. You can test this by changing the NIC type to E1000 which WinPE does have a driver for by default, you actually want to use VMXNET3 of course so get that driver injected in to the image.
Also enable Command Prompt support (F8) on the boot image and also enable Task Sequence debug.
https://www.prajwaldesai.com/sccm-task-sequence-debugger-troubleshooting-tool/
https://linustechtips.com/topic/1263794-sccm-help/#findComment-14169077
I got working. I had to change the DHCP option from hostname to IP address
https://linustechtips.com/topic/1263794-sccm-help/#findComment-14169614
Now I am facing a new problem... I am using the DP as the PXE server. So with WDS and I am getting TFTP timeout..
https://linustechtips.com/topic/1263794-sccm-help/#findComment-14169637
Nice, thought you were getting past that and WinPE was actually booting and was failing there. Btw I've always found it more reliable to use IP helpers at the network layer rather than DHCP option for PXE booting, you can have more than one DHCP Relay address defined and then you just let the PXE servers figure out if they need to respond to the request or not.
Works much better when you have mixed hardware support e.g. BIOS PXE clients and UEFI PXE clients etc.
https://linustechtips.com/topic/1263794-sccm-help/#findComment-14169642
Check the SMSPXE log, see if the request is making through to the PXE service and what the service response was.
https://linustechtips.com/topic/1263794-sccm-help/#findComment-14169647
That is now fixed.. I installed WDS and now I am getting violation access..
https://linustechtips.com/topic/1263794-sccm-help/#findComment-14169665
What does it actually say in the SMSPXE log? It has the exact reason why it won't let a client PXE boot in there e.g. "No Task Sequence assigned to client" etc.
https://linustechtips.com/topic/1263794-sccm-help/#findComment-14169781
For the log
 Operation: BootReply (2)  Addr type: 1 Addr Len: 6 Hop Count: 0 ID: 60418B2A
 Sec Since Boot: 4 Client IP: 000.000.000.000 Your IP: 000.000.000.000 Server IP: 172.016.255.110 Relay Agent IP: 000.000.000.000
 Addr: 00:0c:29:8b:41:60:
 Magic Cookie: 63538263
 Options:
  Type=53 Msg Type: 2=Offer
  Type=54 Svr id: 172.016.255.110
  Type=97 UUID: 00564d5d39b23660bda0196347c18b4160
  Type=60 ClassId: PXEClient]LOG]!><time="10:09:02.165+00" date="11-01-2020" component="SMSPXE" context="" type="1" thread="5888" file="pxedump.cpp:303">
<![LOG[============> Received from client:]LOG]!><time="10:09:04.160+00" date="11-01-2020" component="SMSPXE" context="" type="1" thread="1876" file="smspxe.cpp:666">
<![LOG[
 Operation: BootRequest (1)  Addr type: 1 Addr Len: 6 Hop Count: 0 ID: 60418B2A
 Sec Since Boot: 4 Client IP: 000.000.000.000 Your IP: 000.000.000.000 Server IP: 000.000.000.000 Relay Agent IP: 000.000.000.000
 Options:
  Type=53 Msg Type: 3=Request
  Type=50 Requested IP: 172.016.000.047
  Type=55 Param Request List: 01020305060b0c0d0f1011122b363c438081828384858687
  Type=57 Max Msg Size: 04ec
  Type=54 Svr id: 172.016.000.003
  Type=93 Client Arch: Intel x86PC
  Type=94 UNDI: 010201
  Type=60 ClassId: PXEClient:Arch:00000:UNDI:002001]LOG]!><time="10:09:04.161+00" date="11-01-2020" component="SMSPXE" context="" type="1" thread="1876" file="pxedump.cpp:303">
https://linustechtips.com/topic/1263794-sccm-help/#findComment-14169836
16 minutes ago, Sir Asvald said:
For the log
  Hide contents
 Options:
<![LOG[
 Options:
https://linustechtips.com/topic/1263794-sccm-help/#findComment-14169858
https://linustechtips.com/topic/1263794-sccm-help/#findComment-14169903
10 minutes ago, leadeater said:
hahaha good old Windows 🤷‍♂️
Hahaha. Yah :D
https://linustechtips.com/topic/1263794-sccm-help/#findComment-14169968
