I have a gigabyte rtx 2060 and when i play games like gta need for speed heat hue arc and other games it makes a really weird sound
Is it a coil whine?
What can i do to fix it?
https://www.youtube.com/watch?v=kAKG787XAtY
https://www.youtube.com/watch?v=Ahoce2iOCWk
It only makes that sound when i play games and it gets over 170 180 f
Is it some kind of alert?
I'm not really a computer guy i kinda just play games
https://linustechtips.com/topic/1263554-help/
Is it a coil whine?
It the sound changes in pitch as things move on screen, then it's coil wine. Frankly, not much you can do about it. You'll just have to live with it unless you want to spend more money switching out components.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1263554-help/#findComment-14166394
So there is nothing wrong with it?
https://linustechtips.com/topic/1263554-help/#findComment-14166402
Coil whine is considered completely normal behaviour. Whether or not you get it is based on luck and how well the components you've chosen react with each other.
https://linustechtips.com/topic/1263554-help/#findComment-14166409
Coil whine won't hurt anything other than your sanity really, sometimes downclocking your gpu a little bit can fix it but not really a ton you can do about it
Optical Drive Poll: https://linustechtips.com/main/topic/1006309-optical-drive-survey/
Main Rig (Pulsar)
CPU: Ryzen 7 5800X MOBO: MSI MEG X570 Unify RAM: Corsair Dominator Platinum RG(4x8gb) 3200Mhz 16-16-16-32 GPU: EVGA GTX 1080 FTW ACX 3.0 Cooler: Noctua NH-U12S Chromax (LTT Edition) Storage: Intel 6000p 128gb boot drive, Intel 665p 1tb (x2), Samsung 850 EVO 1tb, Case: Phanteks Enthoo Pro M Tempered Glass PSU: EVGA SupeNOVA G1+ 750W OS: Windows 10 Pro 64 bit
FreeNAS Server (The Vault)
CPU: Xeon E5-2603 v3 MOBO: MSI X99 Tomahawk RAM: G.Skill Aegis (4x8gb) 3000Mhz 16-18-18-38 GPU: EVGA GT 710 Cooler: Cooler Master Hyper 212 LED Storage: Intel S3520 x2 for boot, x16 in RAIDZ for storage, Seagate Ironwolf 2tb (Striped will be a steam cache) Case: Phanteks Enthoo Pro Tempered Glass PSU: Corsair CX750 750W
https://linustechtips.com/topic/1263554-help/#findComment-14166443
