ARGB hub for b450 gaming plus max
Solved by narrdarr,
Gamer storm rgb converter should be fine then.
As far as needing a bunch of ports. Don't worry about it. The second cable hanging off the rgb cable is for you to daisy chain
Featured Topics
Cyber Akuma ·
7
ave11 ·
Posted in Troubleshooting1 -
2
Abstrxction ·
Posted in Storage Devices3 -
3
ImServs ·
Posted in Cases and Mods1
play_circle_filled
Latest From GameLinked:
Are you excited for Doom: The Dark Ages? - Gamers 2 Gamers
