Hi, I am trying to program a 0.91" 32x128 oled using SSD1306 library in Arduino IDE, but when I compile the example sketch for STM32 and upload it, nothing comes on the screen. It did not say where SDA and SCL were so I googled which pins they were and connected it to those. I have the I2C version of the OLED btw
Please tag me @RTX 3090 so I can see your reply
https://linustechtips.com/topic/1262972-how-to-program-oled-with-stm32/
https://www.buydisplay.com/white-2-2-inch-128x32-i2c-oled-display-module-serial-spi-ssd1305
This thing? Or something similar to it? If it's something else, link the datasheet.
Show the circuit you built. I'm in the process of making a PCB for (among other things) controlling this OLED, and here's the circuit I've built (with a lot of help from the datasheet and some friends):
Keep in mind you should also have pullup resistors on SCL and SDA (I have them controller-side) and need at least 20ma of available current for the 12v line (preferably 28ma).
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
For one, you're not specifying which STM32 MCU you are using: there are hundreds of different STM32 MCUs and they don't all have the same pinout. Secondly, are you sure you are using the right I2C-address? If you are using one of those premade OLED-modules, there's typically solder-pads to choose the address with; writing to the wrong address will obviously not display anything on the display.
A common, frustrating, issue is the i2c address. the back of the OLED should have two hexadecimal digits on either side of a resistor. The resistor can be moved around to change the address (if you want to have two independent screens on the same bus or you have another device with a conflicting address). IIRC, the Adafruit library default address is incorrect for the common SSD1306 we all buy from Aliexpress. Try changing the address in your code to the address on the back of your screen closest to the selection resistor.
Also it's possible something is wrong with your code so you should post that too.
ASU
  • 2 months later...
Which code would you recommend me to use (as a base for my project)
Here are pic of the MCU and OLED @WereCatf@kelvinhall05
1610923837892.thumb.jpg.832b1b07e5387aca31b08f68d2574a85.jpg1610923837905.thumb.jpg.97135845c2f6e747a049ce3a7ed0d2ea.jpg
4 minutes ago, RTX 3090 said:
Also just want to double check, which core should I use
Are you talking about Arduino-core for STM32 or what?
5 minutes ago, RTX 3090 said:
and which pins should I connect the OLED to
SCL to SCL and SDA to SDA, obviously. Where they are on the board depends on the board.
I have been using this diagram from Google. Am wondering if it is correct tho
STM32L433CCT6 - Boring_TECH Black Pill | STM32-base project
1 minute ago, RTX 3090 said:
Yes, STM32 with arduino IDE (I dont mind using another so long as it isn't too complicated like cube IDE
An IDE is an IDE, an Arduino-core is an Arduino-core. They are not the same thing, so I still don't know what you're trying to ask.
AFAIK there are only two useable Arduino-cores for STM32, namely Stm32duino and Roger's Clark's Arduino STM32
No idea. You only posted a picture of the MCU, not the board, so how would I be able to tell? If the board looks identical, then it probably is identical.
Which is the thing I should use, stm32duino or roger's core ?
Which is more compatible for my project ?
I'd probably try with Stm32duino first.
1610925853071.thumb.jpg.8fea9364c9a9b8993f9c9bd8e3f7c9ea.jpg1610925853080.thumb.jpg.5ecdd197943fa38d85ba426e7e219065.jpg
Should I use my FTDI as USB bootloader is not working for some reason or is it better for me to try and fix that first
Doesn't matter, do whatever you feel is best. Both ways are fine.
8 minutes ago, RTX 3090 said:
Pictures
That looks to be about the same board as here: https://stm32-base.org/boards/STM32F411CEU6-WeAct-Black-Pill-V2.0.html
This pinout-diagram is probably correct:
The SCL and SDA are probably on PB8 and PB9, but you'll just have to try.
I just wanna test if my board is working first. Will this line work to test the LED
void loop() {
  digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);                       // wait for a second
  digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
  delay(10000);                       // wait for a second
If LED_BUILTIN points to the correct pin (according to the pinout, the LED is connected to PC13), then sure. If it doesn't, then no. If it doesn't work, try with PC13 instead.
That's not an official Arduino-board, it's just a random Chinaman-board and you'll just have to google details or suss things out on your own. I, also, do not have that board.
If LED_BUILTIN points to the correct pin, then sure. If it doesn't, then no. That's not an official Arduino-board, it's just a random Chinaman-board and you'll just have to google details or suss things out on your own. I, also, do not have that board.
Thanks for info. Is this error because I did not do a setup or because I am using the wrong pin as you sugested
21 minutes ago, RTX 3090 said:
It is now giving this error. Do I have to hold a button or something while uploading the code ? Does boot mode config mean I never pressed the button before plugging it in
Press and hold the boot0 - button down until it has successfully begun the flashing - process. Or, if that doesn't work, press the boot0 - button down and hold it, then press nrst, then release the nrst and then release boot0, after which it should be in flashing-mode.
Hi, thanks, it is flashing perfectly with LED_Builttin now
So should I install the GFX library for Adafruit or is there one made specifically for STM32
