Budget (including currency): $1200-1800 USD
Country: United States
Games, programs or workloads that it will be used for: Mostly gaming (Rocket league and WoW), Ableton, and I would like the capability to do video editing/rendering.
I'll need Windows 10, 1 or 2 monitors and a keyboard as well, preferably mechanical. I am not picky about the case as long as it looks clean. Clear or closed front and side panels are fine.
As this is my first PC build, I don't know much about buying these items. Do the necessary cords come with the parts (besides power cord, ethernet, USB I probably don't have any of the right wires)?
As to as why I fell I should upgrade; I've been using a 2012 Macbook Pro for the last 7 years and it is becoming almost unusable.
Thanks in advance for any and all help!
https://linustechtips.com/topic/1262768-first-gaming-pc-build/
yes, the power supply will have all the power cables, the motherboard will have SATA cables for the hard drives and SSDs, the case will come with the screws to mount everything, and if you get an RGB cooler, the RGB cables will come with it.
AMD just announced the RX 6000 series cards and they would fit nicely into your budget. I recommend waiting a month if you can and asking again in the future for a parts list when the new products are available.
If you must build now, here is a parts list
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1262768-first-gaming-pc-build/#findComment-14159713
Awesome, thanks for the info!
https://linustechtips.com/topic/1262768-first-gaming-pc-build/#findComment-14159727
Just now, Buckdavis said:
Awesome, thanks for the info! I'll just delete this post and do it again when they release.
don't worry about deleting anything, admins are the only ones who can delete posts anyway. you can just make a new one with the same format in the future.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1262768-first-gaming-pc-build/#findComment-14159730
Fasauceome reccomend a great built but if you can wait for the rx6800 I highly reccomend it as it will give you much better preformence than the 5700xt while still staying under budget
https://linustechtips.com/topic/1262768-first-gaming-pc-build/#findComment-14159779
