Silent Base 601
Johnny999
Hi, I need to buy a new case because of coil whine which is very apparent while playing RDR2 (what I wouldn't do for that game lol) and I have been looking at the be quiet! Silent Base 601. My question is, would it be too much of an oven with 3x 140mm Silent Wings 3 PWM fans in the front, 3x 140mm in the top and 1 in the rear? CPU cooler is Dark Rock Pro 4 and GPU is the RTX 2060 Super Gaming X. What do you think?
With so many fans it should be fine. I'd probably only do 3 fans in the front, 1 in the back and 1 at the top back. The other 2 top fans would just suck out fresh air before it hits anything to cool. Also check again if the case supports 3x140mm fans in the front, most cases only support 3x120mm.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
I run the exact specs, three 140mm silent wings in the front and one in the back, only difference is I only run a dark rock 4 on a 3600. temps are in the high 60s for everything, and thats without even turning the fans above 800rpm. Dont do the 3 in the top, they have no room to breathe anyways.
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
High 60s idle? What do you mean everything.
They do, according to be quiet!
High 60s full folding load with 105% power limit on the gpu and cpu folding running as well
With everything i meant gpu and cpu temps.
Room temp around 22°C
Even if it sometimes hits low 70s, it aint bad
- Ryzen Build -
2x Dell UP2516D
yeah it does, running it myself
- Ryzen Build -
2x Dell UP2516D
Wow that is much better than what I expected for this case. Thank you.
Part of it is clearly the cooler design. But "bad thermals" for this case just means it runs roughly 5 degrees cooler without the front panel at the same fan speeds.
- Ryzen Build -
2x Dell UP2516D
Which one would be better temperature-wise? Pure Base 500 with 5 140mm fans or the Silent Base 601 with 7.
Pure _Base 500 "DX" with 5 140mm fans
get the DC version. it ism uch better than the normal 500
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
Well that is the one I have now.
then silent base 600 with 7 fans. 500 DX is really good case.
Main PC:
Test Rig.
Just Sold
Ask me anything :)
It is, it is the motherf****** RTX 2060 Super Gaming X that is whining like a b**** while I play RDR2. And RMA is not worth it since GPUs without coil whine seem to be very rare.
silent base 600 should help a lil bit
Main PC:
Test Rig.
Just Sold
Ask me anything :)
reducing the power limit/undervolting slightly should reduce coil whine.  Are you running the power limit higher than stock?
I haven't touched the card in Afterburner at all (don't even have it installed). The card only whines when I play RDR2 with the power mode set to adaptive/prefer maximum performance (in NVidia control panel) instead of optimal because optimal gives worse performance.
