Budget (including currency): £750
Country: United Kingdom
Games, programs or workloads that it will be used for: Rocket League, Racing games. Star wars games e.g fallen order, squadrons. Adobe Creative Applications
Peripherals will be upgraded later.
1080p75hz atm, upgrading next year.
Parts List:
Ryzen 5 3600 (Purchased)
Be Quiet Pure rock slim (Not sure about)
Phanteks P400A Digital
Aorus X470 Ultra Gaming
Nvidia GPU budget of around £300
Sharkoon SilentStorm Cool Zero 650W
Samsung 860 Evo 512gb
1tb WD Blue HDD
So, I don't know what motherboard to get. Some say that the one I chose is not great if I want a better CPU, I don't. So should I change it?
Also I don't know what GPU to get, it has to be Nvidia as I use Adobe premiere aswell as After Effects and they work much better on Cuda. Any suggestions? I'm open to buying used
So, I'm wondering, should I spend £305 on GPU and go with the cheap cooler or spend an extra say £15 and get something like a Pure Rock 2?
Any other suggestions are welcome too, but I would really appreciate answers to my questions.
Thanks guys
System
CPU: Ryzen 5 3600
Case: Phanteks eclipse P400A
Motherboard: MSI B550 Gaming Carbon WiFi
GPU: MSI RTX 3060 TI Gaming X Trio
RAM: 16GB XPG D60G CL16 3200MHZ
PSU: Sharkoon SilentStorm Cool Zero 650W
Storage: Crucial P2 1TB
https://linustechtips.com/topic/1262457-updated-build-plan-advice-please/
5 minutes ago, CloudPC said:
-snip-
-snip-
I can't speak on the motherboard for AMD. I've not messed with them. Why not use the stock cooler? I've heard good things about them.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
stock cooler is fine, board is fine for a 3600/3700x/5800x probably. card-wise, a used 1080ti would be a monster, for new cards a 2060 ko would be best regarding things that are actually in stock atm
topics i need help on:
my "oops i bought intel right before zen 3 releases" build
CPU: Ryzen 5 3600 (placeholder)
GPU: Gigabyte 980ti Xtreme (also placeholder), deshroud w/ generic 1200rpm 120mm fans x2, stock bios 130% power, no voltage offset: +70 core +400 mem
Memory: 2x16gb GSkill Trident Z RGB 3600C16, 14-15-30-288@1.45v
Motherboard: Asus ROG Strix X570-E Gaming
Cooler: Noctua NH-D15S w/ white chromax bling
OS Drive: Samsung PM981 1tb (OEM 970 Evo)
Storage Drive: XPG SX8200 Pro 2tb
Backup Storage: Seagate Barracuda Compute 4TB
PSU: Seasonic Prime Ultra Titanium 750W w/ black/white Cablemod extensions
Case: Fractal Design Meshify C Dark (to be replaced with a good case shortly)
basically everything was bought used off of reddit or here, only new component was the case. absolutely nutty deals for some of these parts, ill have to tally it all up once it's "done" :D
How many quid do you still have
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
I purchased the CPU used on eBay. It didn't not come with stock Cooler. Also, I want it to be quiet and I imagine that the stock is quite loud.
I'm tempted by a 1080ti but I worry about it not having the nvenc encoder aswell as it being 4yr.
Will game performance be bad if I'm recording while playing?
System
CPU: Ryzen 5 3600
About £550
System
CPU: Ryzen 5 3600
in that case a 20-30 dollar tower cooler would be fine, the 3600 is very low power and doesnt need anything fancy. something like a hyper 212, gammaxx 300/400, etc.
all nvidia cards since kepler (i think) have some type of NVENC encoder. though the most recent turing NVENC is the most efficient, pascal's isnt bad either and you can still find used 1080tis that are about 2-2.5 years old with warranty left over. a 2060 would be fine though; good for 1080p, good for video editing, latest NVENC, all that. using the NVENC encoder has a negligible effect on gpu performance which is why its so useful for streamers
The system that you have picked out already appears to be really good. I would recommend a decent air cooler of anything with a 120mm or 140mm fan if you can fit it in the P400A since you plan on doing video editing to keep temperatures down.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
So obviously the 1080ti is better in game performance.
Do you really think I could get one for £300?
If so I think I may just go with that.
Oh I should have mentioned before, I will not buy the rest of the parts till November 27th as it's black Friday then and there should be done deals.
System
CPU: Ryzen 5 3600
Thanks, yeh hopefully prices drop so that I can afford a better cooler.
System
CPU: Ryzen 5 3600
in the us i can get one for 350 bucks or less shipped to my house, so i'd assume that you can find a local deal on one at least.
