i have a douht i need a pc for 3d desgining and some gaming and i am confused what to buy a pc or a laptop plz help me!!!!!!!!!!!!!!!!!
7 members have voted
  1. 1. i have a douht i need a pc for 3d desgining and some gaming and i am confused what to buy a pc or a laptop plz help me!!!!!!!!!!!!!!!!!
    • laptop
    • pc
I didn't know what douht means but if you're doing anything where you need to pick your PC to and go somewhere with it, using it somewhere like on the bus, the laptop is your only option.
Otherwise, you can always get a more powerful desktop for the same price.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1262252-help-me-plz/#findComment-14154962
i would second this, if possible try to get a PC since it can be upgraded year over year.
https://linustechtips.com/topic/1262252-help-me-plz/#findComment-14155018
Think he means DOUBT 🤔
DISPLAYS: LG 27UL500 IPS 4k60hz + HDR and LG 27GL650F IPS 1080p 144hz + HDR
LAPTOP: Lenovo Legion 5 CPU: AMD Ryzen 7 5800H GPU: RTX 3070 8GB RAM: 16GB 3200MHz (2x8GB DDR4) STORAGE: 4TB Crucial P3 NVMe SSD + 2TB Samsung 970 evo plus NVMe SSD DISPLAY: 1080p 165hz IPS OS: Windows 11 Pro x64
https://linustechtips.com/topic/1262252-help-me-plz/#findComment-14155047
* Thread moved to the New Builds & Planning section *
Please see the section guidelines and give as much details as possible for users to help.
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/1262252-help-me-plz/#findComment-14155245
