I started up Jedi Fallen order and all was well, but then suddenly one of the fans on my Asus GTX 1070 started revving up to full speed. I went into MSI Afterburner but I found out I no longer had control over the fan speeds. Also in HWmonitor it said that the fan was at 200-500rpm when it actually were at 1500rpm.
I began with doing a clean sweep with DDU and fresh drivers, but as soon as i log in and the driver kicks in the fan revs up again.
I then were clumsy enough to touch the fan so the blades broke, and i had to place an order for a replacement fan, then i disconnected the broken fan. It's this fan I'm referring to btw: https://imgur.com/a/BJFkug3
Now it runs on 2 fans, and i still have no control. And it's also this weird buzzing noise sometimes..
Games run just as it did before with no issues, thermals also seem to hold up fine with 2 fans..
I tried running a VBIOS update but it says that there is no need.
So now I'm sitting here with 2 fans that live their own life and a weird buzzing noise.
A small detail to mention is that i got a new monitor yesterday with 144Hz 1440p HDR, if that matters at all.
Help anyone? I'm planning on upgrading to a 3080 but that's not in stock for a long time it seems.
https://linustechtips.com/topic/1261185-lost-control-over-gpu-fans-help/
I think I may have fixed it!! The VBOIS actually updated something when i tried again.. I can now control my fans again.
I followed this thread if there is someone else stumbling over the same problem: https://rog.asus.com/forum/archive/index.php/t-88228.html
