1 minute ago, RAM555789 said:
So your saying your friend goes very quiet and echoy or is it you? Does this happen with 1 specific friend, or with everyone? Do you experience changes in audio in other applications besides discord?
My friends dont experience My mic going quiet it even happens when im watching youtube It goes what I just said I click the audio on discord and select the speakers im on then it works for a bit and it keeps repeating
https://linustechtips.com/topic/1261065-help/#findComment-14145631
Just now, I am called A RTX2070 said:
It sometimes happens to one application then I fix it then it happens to another
What do your normally do to fix it and what headphones are you using. Also did you mean your mic goes quiet and application go quiet? Is it usually 1 application at a time or multiple?
https://linustechtips.com/topic/1261065-help/#findComment-14145641
well my mic doesnt go quiet my speakers do (I dont wear headphones lol) 1 application then I fix it by re clicking on the speakers in the audio settings
https://linustechtips.com/topic/1261065-help/#findComment-14145646
4 hours ago, RAM555789 said:
Try using "Loudness Equalization" under your speakers properties.
Done? Now I will test one second
High CPU usage shouldn't cause random drops in your audio. Perhaps it could be the editing of the audio in DaVinci
No I dont think it is a problem with the speakers cause one application goes down and the other is still good
Im exporting in davinci btw
Audio Dropped again
On google
image.png.a352e5fb3804a00caf45b2d344d5070f.pngThermal censor problem?
This is Celsius
https://linustechtips.com/topic/1261065-help/#findComment-14145663
@I am called A RTX2070 multiple of your posts have been merged. This isn't chatroom. Please edit more info into your posts rather than post again. You can bump your thread once a 24h if needed, but otherwise doing so is seen as spamming.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1261065-help/#findComment-14145963
