i have a desktop pc with the MSI H110M PRO-D motherboard and Micron Technology 8ATF1G64HZ-2G3A1 8GB 2400 MHZ 1.2v  ( i think it's 1.2V that's what memorybenchmark.net say ) yesterday i added a Teamgroup 8gb 2400MHz ( 1.25v) sick the pc ran fine but i think the electricity in my house when down and since than when i run them together the pc is unstable  some bluescreens and freez i don't know what happend , maybe it's a voltage problem , i tried to run it on at 2133mhz same problem and i can't control the voltage of the dram it's locked on auto in my motherboard what should i do
https://linustechtips.com/topic/1260096-i-have-some-ram-problems/
did you clear cmos
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
1 minute ago, chocofoxy said:
yes i did because the pc didn't want to run at 1st when i open it shutdowns after 1s so i cleared the cmos and the pc ran
the 2 sticks cant run in dual channel then
Bios database
prior build:
Just now, chocofoxy said:
i think an old ms-tech 450w
It should be replaced regardless of the RAM problem,it might have contributed to that problem as well.
Try running the PC with just one stick.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
but they ran fine before electricity goes down i even full loaded them with a python neural net script and nothing happend
what are your full system specs?
Bios database
prior build:
when i run it on onestick it runs fine
So the sticks are not compatible with each other.
1 To toshiba HDD
oof.
that seems to be a pos psu. I would get a new psu and a new kit of ram.
Before you do that, what bsods are you getting?
Bios database
prior build:
On 10/21/2020 at 12:27 PM, chocofoxy said:
Memory managment
Sounds like your power supply damaged something that is related to your RAM or even the RAM itself...
That power supply is dangerous,it can literally explode or light your house on fire...
