I need stress test for linux
Go to solution Solved by svmlegacy,
5 minutes ago, Ataxion said:
how can I download mprime on ubuntu I found the download but it doesn't work
Open the directory in terminal and execute ./mprime
I need a stress test for my linux laptop because sometimes while watching videos the fan ramps up and when I check it it is around 70c but when I tried stress tests that use the terminal the cpu tmeperature didn't go above 60c so I need a working stress test.
Some guy interested in tech
https://linustechtips.com/topic/1259956-i-need-stress-test-for-linux/
What distro?
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
You could try Blender. They provide a number of files you can test witth: https://www.blender.org/download/demo-files/
Also, command line tools aren't inherently less intensive. I've found ffmpeg, a video encoder/transcoder tool, to sometimes successfully reveal failed overclocks.
A story about that: On a Windows 10 machine, my Intel Core i7-6700K was running at 4.6 GHz for months. Absolutely no BSoDs, crashes, etc. despite being on almost 24/7 (I sometimes put it in sleep mode). But then I went to encode a video with ffmpeg, and ffmpeg would either crash or watchdog timeout Windows 10. I lowered the OC to 4.5 GHz and it worked! Again, pretty much nothing else crashed. It was 100% stable in gaming and 3D rendering. It took video encoding to reveal it was not actually as stable as I thought. In retrospect, I probably could've raised the voltage a little bit or tweaked LLC to keep 4.6 GHz, but I probably chose not to because it was already running hard at 1.35 V which was a little high for a Cooler Master Hyper 212 EVO already.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Linux - Fedora
you could do this, though i dont know how long your pc wil last
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
1 minute ago, Ataxion said:
LOL my laptop crashed instantly
you ran it? Do you want to know what it does?
Bios database
prior build:
Just now, Ataxion said:
no what does it do
bassically, it takes : and makes it send itself to the program twice. then, it sends it to it self twice every time it recieves it. so you hav 1, then 2, then 4, then 8, next 16, 32, 64, 128, 256, ect, over and over untill it just breaks everything.
Bios database
prior build:
that explains why my loptop just stopped instantly it only has 4gigs of ram
yeah, someone told me about it, and im too scared to run it. my linux desktop has 3gb of ram.
Bios database
prior build:
It says online that it wont hurt your hardware you just have to restart your pc
Yeah, me. I didn't think anyone was crazy enough to run that, apparently I am wrong!
Hi @Ataxion
For Debian based distro's you can use the following:
Stress:
Install with:
sudo apt install stress -y
run with:
stress --cpu 2
stress-ng:
Install with:
sudo apt install stress-ng
run with:
stress-ng --cpu 4
Geekbench:
Install with:
sudo wget http://cdn.geekbench.com/Geekbench-5.2.3-Linux.tar.gz
sudo tar xf Geekbench-5.2.3-Linux.tar.gz
//Once you have extracted the file, run the following command to launch Geekbench.
cd Geekbench-5.2.3-Linux && ./geekbench5
//when the tests are completed, you will get a URL link
Hope this helps you
