Budget (including currency): $1,500 USD
Country: United States
Games, programs or workloads that it will be used for: Video Editing (Premiere & After Effects), Streaming (Using OBS), Gaming (Witcher 3 & Destiny 2)
A friend asked for help with building a PC since she's coming from a Mac. I'm not the best a picking parts, seeing as how I've yet to build my own PC, but I figured PCPartPicker and a bit of knowledge would bring me a decent part of the way there. I do have a parts list, which I would appreciate feedback on and also suggestions on where I could cut cost without sacrificing too much in terms of performance.
While the budget isn't too limiting, I've already picked parts that exceed that by about $500 USD. I wanted to try and pick parts that would last her a fair amount of time, but I'm probably going overboard for what's strictly necessary
AMD Ryzen 9 3900X
GIGABYTE X570 AORUS ULTRA ATX AM4
Corsair RM (2019) 750w 80+ Fully Modular
EVGA GeForce RTX 2070 SUPER 8 GB Black Gaming
Corsair Vengance RGB Pro 32 gb (2x16GB) DDR4-3600 CL18 Memory
Western Digital Black SN750 NVMe 500GB m.2 2280 SSD
Samsung 860 EVO 1TB 2.5" SSD
Western Digital Black 4TB 3.5" 7200RPM HDD
Corsair h115i RGB PLATINUM 97 CFM Liquid CPU Cooler
Phanteks Eclipse P350X ATX MidTower
After looking for pricing and availability, I ended up with a total $2,070.91.
Also, while she would like RGB Lighting, I'd prefer to focus on performance first and foremost. Even if that means she doesn't get much in the way of rainbows everywhere.
https://linustechtips.com/topic/1259566-need-help-planning-a-build/
little over 1300 with room to upgrade RAM, GPU, or more storage. 1660 is good to start off but  right now is now the best time to buy a GPU since 3000 series are out and new AMD GPU coming out on the 28 I think, I would wait till next year to upgrade since  3000 GPU won't be in a high demand like now. I personally wouild go with the 3070 for 499. WIth 200 you can buy another the same ram kits or go with  8 more TB of HDD storage or 1-2 TB of more SSD storage.
Thanks so much for the help! I figured that I went a bit overboard for performance. Everything looks good here so I'm going to forward this list to my friend.
