There's a whole bunch.
Biggest is syntax which requires round brackets for parameters
ASCII to Unicode and some others
Many more included libraries with 3 compared to 2, etc
One major "difference" when it comes to using Python is that the official support for Python 2.X ended earlier this year. This means that Python 2.7 will neither get any improvements nor security fixes going forward (the latter one being the bigger issue).
That was always required for functions IIRC, but not keywords. The change with 3.x was that many keywords are now implemented as functions.
____________________________________________________________________________________________________________________________________
pythonmegapixel
into tech, public transport and architecture // amateur programmer // youtuber // beginner photographer
Thanks for reading all this by the way!
By the way, my desktop is a docked laptop. Get over it, No seriously, I have an exterrnal monitor, keyboard, mouse, headset, ethernet and cooling fans all connected. Using it feels no different to a desktop, it works for several hours if the power goes out, and disconnecting just a few cables gives me something I can take on the go. There's enough power for all games I play and it even copes with basic (and some not-so-basic) video editing. Give it a go - you might just love it.
