B450M-Pro4 vs B450-Pro4
Go to solution Solved by Tristerin,
Just now, Ligonsker said:
Thank you!
Are all the ports working? Quick search shows that many people report on ports that stopped working, such as the USB-C that don't work
Why would they do it, I mean they specialize in motherboards, at least make the naming convenient as well to make your customers understand what's going on
Not sure about anyone else but I dont have issues with this board.  10/10 would buy it again.
Hello,
I was about to buy a cheap B450 motherboard just to put my 3400g, and maybe do a little overclock for fun, because I've never done it.
After seeing that the cheap B450 do not have heatsink on the SoC VRM, and that they have bad voltage delivery in general, I avoided buying one of them
Then you suggested me the ASRock B450M-Pro4. But including taxes and shipping it's about 140$, and I found a better deal for 90$ including tax and shipping for new B450 (not mATX).
But I wanted to ask you if it's worth it? How is this ASRock mobo cheaper yet has much better specs and features. Is the build quality bad? The connectors do look flimsy in the photos.
*Is the B450 as good as the B450m? (apart from being larger)
Now I want to OC for fun, but I don't want it to come on the expense of the build quality. I don't want the ports to easily break, if that's the case and the reason ASRocks are cheaper, I'd prefer not to OC and just get the best build quality mobo
*It's my first PC in 10 years, that's why I make such a big deal of such a simple part
CPU: Ryzen 5 3400g
RAM: 2x4GB 2666Mhz Ballistix Sport LT
Storage: Samsung 970 Evo 500gb
PSU: Corsair CX550
The mATX and the ATX b450 pro4 are the same in terms of vrm, just difference in form factor, it's quite a decent budget board.
Compared to what exactly?
It's a pretty good budget board.
Phone: Pixel 3a (Purple-ish).
Build Log:
I slap 140+ sustained amps through that board and push my R7 1700 to 4.2ghz with it.  I love that budget board.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
looking at motherboards, it would seem that MSI are the only ones right now with a habit of using the same name on very different boards. Specifically the MSI B450 A-Pro and the B450M A-Pro appear to be radically different, despite implying the size is the only difference.
Trash beauty:
CPU: Xeon X5550
GPU: RX 570 4GB (defective)
SSD: Fattydove Racing 240GB
HDD: WD Blue 320GB
Motherboard: HP Z400
Ram: 6x2GB DDR3 1066
PSU: Corsair TX650
Thank you!
Thank you!
The pro4 is one of the best budget AM4 lineup.
If the full ATX is cheaper i'm surprise, since usually the bigger one is more expensive.
Why not get the B550 instead.
Alright this board it is! Now I need to change the case from mATX case to some compact one that supports ATX
My budget is limited and the B550 are way too expensive. It's weird because on Amazon.com the B450m-Pro4 is 83$, but I need to add taxes and shipping and it goes to 140$. On a european Amazon I found the B450 non M for 66 euros which is less and also tax and shipping is lower
I have built a couple of PCs with the Asrock B450 Pro4 and the B450M Pro4. In my opinion they are really very good boards, connectors feel about the same as more premium boards (they probably use the same part) and they have all been rock solid. Highest power CPU I put in one was a 2700x, handled it like a champ.
Main Rig: CPU: AMD Ryzen™ 9 3950X Processor (Stock, -0.1V offset)  /// Motherboard: Asus Pro WS X570-Ace /// CPU Cooler: Deepcool GamerStorm Castle 360 RGB V2 /// GPU: Gigabyte AORUS GeForce® RTX 2080 SUPER™ 8G /// RAM: G.SKILL Ripjaws V 128GB (4x32GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R6 USB-C Blackout TG /// PSU: Corsair RM850i /// Storage: 500GB Samsung 970 EVO Plus NVMe (boot) + 1TB WD Black SN750 NVMe (Working Drive) + 2x 1TB Samsung 850 EVO 2.5" SATA SSD RAID0 (Game Library) + 2TB Seagate BarraCuda (Backup) /// OS: Windows 10 Pro
Peripherals (Main Rig): Mouse: Logitech MX Master 3 + Logitech G903 Lightspeed /// Keyboard: Keychron Q1 ANSI - JWK Lavender Linear Switches (TX Switch Film, Krytox 205g0), Durock V2 Stabilisers, Polycarbonate Plate, Tape Mod, GMK Blue Samurai + Keychron K4 V2 Hotswap RGB Aluminum Frame - Gateron Milky Black (Deskeys Switch Film, Krytox 205g0), Foam Mod, Tape Mod, GMK Rainy Day PBT Clones /// Tablet: Wacom Intuos M BT /// Monitor: 4x LG 27UL500-W (4K IPS Freesync) /// DAC: Focusrite Scarlett 2i2 /// Speakers: Logitech Z625 /// Mic: Focusrite CM25 MkII /// Headphones: Audio-Technica ATH-M50x, ATH-LS70iS IEMs /// Racing Wheel: Logitech G920 Driving Force with Shifter /// Eye Tracker: Steelseries Sentry  /// External Drives: 500GB Samsung T5 SSD (Working Drive)
Home Server - NASty: CPU: AMD Ryzen™ 7 2700x Processor /// Motherboard: Asus PRIME X470-Pro  /// CPU Cooler: be quiet! Dark Rock Pro 4 /// GPU: Gigabyte GeForce® GT 1030 OC 2G /// RAM: G.SKILL TridentZ RGB 64GB (4x16GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R5 Window /// PSU: Corsair RM750x /// Storage: LSI SAS 9211-8i (IT Mode) + 10x 4TB Seagate Exos Enterprise Drive /// OS: UNRaid
Tester Rig: CPU: AMD Athlon™ 200GE Processor /// Motherboard: Asus ROG Crosshair VI Hero WIFI  /// CPU Cooler: AMD Wraith Prism RGB /// GPU: Palit GeForce® GTX 1050 2GB StromX /// RAM: Klevv Bolt 8GB (1x8GB) 3000Mhz CL15 /// Chassis: The AMAZING $30 "Computer Case"! /// PSU: Seasonic Focus GX-750 /// Storage: 1TB Samsung 860 EVO 2.5" SATA SSD + 240GB Transcend SSD220S 2.5" SATA SSD /// OS: Windows 10 Pro
Laptop (Asus UX430UN): CPU: Intel® Core™ i7-8550U Processor  /// GPU: NVIDIA GeForce MX150 /// RAM: 16GB 2133Mhz /// Storage: 512GB SanDisk SD8SN8U512G1002 (boot) /// OS: Windows 10 Home
Other Tech: Console: Xbox One S 1TB, Apple TV 4K /// Printer: Canon imageCLASS MF635Cx /// Phone: Apple iPhone 12 Pro Max 256GB Graphite (Daily Driver)  /// Tablet: Apple iPad 9.7-inch Wi-Fi (2018) 32GB + Apple Pencil (1st Generation) /// Headphones: Apple Airpods Pro, Sony WF-1000XM3, Sony WH-1000XM3 /// Smartwatch: Apple Watch Series 6 GPS Space Grey
Cameras: Bodies: Canon EOS-1D X Mark II, Canon EOS 5D Mark IV,  Sony A6000 /// Lenses: Canon EF 24-70mm F/2.8L USM, Canon EF 16-35mm F/2.8L II USM, Canon EF 70-200mm F/2.8L IS II USM, Tamron SP 150-600mm F/5-6.3 Di VC USD G2 (Canon), Sony SEL-P1650 E 16-50mm F3.5-5.6 PZ OSS /// Lighting: 2x Godox SL60-W Continuous LED, 2x Canon Speedlite 580EXII /// Tripods: Leofoto LS-324C Carbon Fiber Tripod + Leofoto LH-40 Ballhead, Leofoto MC-80 Multipurpose Clamp, Triopo DG-3 Gimbal Head /// Yes, I am a Canon Fanboy, deal with it
Thanks now I'm more confident about this board. B450 Pro4 it is
  • 2 months later...
I have bought three or four of them. Had some fun overclocking. All of them still work to this day, they're my go-to boards when building pcs now.
