Hello,
I am running an Unraid server with Shinobi Pro and using swag for encrypted connection via the internet. I am running into a problem where after the last update to the docker image, I am unable to view any monitors, cpu usage, ram usage or storage usage. I am able to access settings. If I connect to shinobi via LAN, I am able to view everything like normal. I am able to add monitors through the internet connection, but I can only view the added monitors in the LAN connection.
Reddit post below seems to have the same exact problem.
Any help?
https://linustechtips.com/topic/1258750-shinobi-pro-web-view-issues/
