Boot problems
Hello
I just built a new pc, it’s my first time but when I tried to install Windows it keeps giving me the message<<Reboot and select proper boot device>> all the parts are new the USB is normal. I’ve tried changing the priority order in the bios
Need help don’t know what to do.
https://linustechtips.com/topic/1258153-booting-problems/
27 minutes ago, JaviEduardo said:
Boot problems
Hello
Do you have a “proper boot device”?  The general method is to have a “proper boot device” in the form of a USB key with windows on it that will install windows on another drive.  The boot order shouldn’t matter.  If it finds a device isn’t bootable it will just go to the next device.  It seems to think there are no devices at all that are bootable
https://linustechtips.com/topic/1258153-booting-problems/#findComment-14120842
