hey so I went in game, opened my afterburner
and it was doing alright. after a while I closed the game and noticed the noise is not going down
checking it there is 0 noise difference between 0 speed and 100% speed gpu fan on afterburner.
when i shutdown the computer it stops or goes quite low, but when I open after burner it goes to max 100% again and no matter if I go manual or change the curves it wont stop going 100%.
my graphics card is a 980Ti Msi
https://linustechtips.com/topic/1258009-lost-control-on-fan-speed/
Reinstall afterburner.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
I did it didn't work, do i have to do something specific to 'clean' reinstall it?
I noticed one of my fans didnt even turn (had this problem when afterburner wasnt working when I bought the card 6-7 years ago), when I lightly touched it with something, it started moving but at a very very slow pace.
the other one is going 100% no matter what
Did you try uninstalling and reinstalling the drivers with DDU?
And is Afterburner up to date?
afterburner is upto date,
I notice its the control of the speed that is weird
so if I put afterburner on 0 automatic it stops turning, but if i set it to 1%, it goes immediately to 100%
i didnt try reinstalling drivers, whats DDU? I'll try that next.
