Hi there I have recently ordered a new pc as my current is getting old and outdated. With this build i have the 4000x Case from corsair and some other components with Corsair iCUE support. As it is my first time working with RGB do am I able to control all the fan RGBs via the lighting node included in the case or am I required to buy the commander pro. I need to buy some fan splitters as my motherboard doesn't have 6 4 pin headers. I am also getting the Hydro series H100i with RGB fans and some vengeance pro RAM. Just wondering as i want to make it easier for myself in the long run. Thanks
https://linustechtips.com/topic/1257782-help-with-case-rgb-lighting/
the lighting node does just lighting.  The commander pro does lighting, fan speed and has the ability to run temp sensors.  If you are going to stay within the corsair eco system of components, then i would recommend getting the commander pro.  It also allows up to 6 4 pin pwm fans i beleve
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
