so im running a 3600 on a gigabyte b550I aorus pro ax with 3200 cl16 ram, in ryzen master no matter what i do the peak speed never reaches 4.1ghz and usually hovers around 4.0 at peak load. my effective clock in hwinfo reaches 4192 but the discrete clock doesn't. i can get up to 4150 on both ccx's at 1.25v with clockTuner so i know i can reach 4.1 ghz with my silicon. is this normal and I'm not comprehending the info or is something up?
cooler: alpenfohn black ridge with noctua a9x14hs (LNA)
my pronouns are they/them
https://linustechtips.com/topic/1257402-ryzen-3600-boost-issue/
What you're seeing is pretty normally I think. 3rd gen ryzen seems to rarely ever hit or come close to hitting advertised boost clocks unless under very specific loads. I believe it'll only boost up in short, single threaded tasks, while sustained all core loads will have lower clocks across all cores.
print "Hello World!" ("Hello World!")
https://linustechtips.com/topic/1257402-ryzen-3600-boost-issue/#findComment-14114388
Does it look like this for you?
Because that's about normal, depending on the workload and how many cores are used.
I regularly hit 4.2, but while gaming and such it's more like 4.0, which again is "normal" the CPU works as intended
Edit: not sure why but imgur didn't work right, it's the right screenshot now
-Scott Manley, 2021
https://linustechtips.com/topic/1257402-ryzen-3600-boost-issue/#findComment-14114756
