Need help: computer freezes on startup
Recently my computer has started freezing on startup, sometimes requiring multiple hard reboots before finally working satisfactorily. Strangely, however, the computer performs perfectly once this initial hurdle is overcome, not freezing at any other moment. I have no idea why this is the case but I would really like to solve the issue. Would greatly appreciate any help.
https://linustechtips.com/topic/1257016-need-help-computer-freezes-on-startup/
you can try
update BIOS
update windows
update chipset drivers
If none of that helps you have to start checking parts by either removing them (like secondary hard drives etc) or replacing them , at least temporarily to see if something is faulty.
Most likely motherboard, psu. cpu, gpu rarely make issues like that, but it's possible also.
ps: since it's on start up... most likely psu
-Scott Manley, 2021
