7 minutes ago, OvErclOCKeR said:
What is the BEST sound card money can buy?
Probably a Xonar Essence or Soundblaster AE-7. But honestly getting an external DAC and AMP would be a better use of your money compared to a fancy sound card. There's a reason why sound cards are pretty niche these days.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1256901-sound-cards/#findComment-14110322
thanks. Getting a sound blaster, but not sure if i could get a better card
https://linustechtips.com/topic/1256901-sound-cards/#findComment-14110327
Just now, OvErclOCKeR said:
What cans do you have that require this?
https://linustechtips.com/topic/1256901-sound-cards/#findComment-14110348
I honestly have no clue what you mean by cans
Headphones
https://linustechtips.com/topic/1256901-sound-cards/#findComment-14110359
2 minutes ago, OvErclOCKeR said:
Just went and copied this from some of my previous answers,
"We tend to not recommend 'true' 7.1 headsets here because in real life humans only hear in stereo, two ears creating a binaural 3D image using the minuscule delay between ears (due to the speed of sound) and spectral pinnae cues to localise the audio. The much smaller, multiple, drivers in true surround headphones are each less accurate than the two single drivers in stereo headphones while driving up cost for no benefit in applications with binaural stereo (and given Windows sonic can turn any 7.1 source into binaural audio, many applications don't even need that)."
In short 'virtual surround' is actually more true to life (at least as far as headphones go) than 'true' surround sound. You can use audiophile headphones to hear virtual surround sound.
Also, those headphones are USB powered so you can't use them with a soundcard...
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
https://linustechtips.com/topic/1256901-sound-cards/#findComment-14110377
You don't need a soundcard to run these. They don't even connect via a primitive connection. They go by USB A->C
https://linustechtips.com/topic/1256901-sound-cards/#findComment-14110379
1 minute ago, OvErclOCKeR said:
that headphone is not worth getting addtional sound gear over It's not great its just you average overpriced RGB piece of Gaming gear.  it comes with it's own USB solution sorata like a soundcard but made for that headset
https://linustechtips.com/topic/1256901-sound-cards/#findComment-14110381
I know. Just to boost the sound quality.
It won't, it can't, don't bother
@rice guru
https://linustechtips.com/topic/1256901-sound-cards/#findComment-14110389
You literally gain nothing.
You aren't connecting via the soundcard.
Not to mention those headphones are going to be garbage compared to an audiophile set
https://linustechtips.com/topic/1256901-sound-cards/#findComment-14110392
Just now, rice guru said:
I mean if you can spend that much on a gaming PC Im sure you can spare some extra cash on a half decent headphone  and mic setup.
I agree,
To be honest this really looks like one of those 'this is the most expensive thing I could buy' builds that isn't really what you plan on buying at all. If I was to actually evaluate that build I'd say it's quite poor for the money.
@rice guru
https://linustechtips.com/topic/1256901-sound-cards/#findComment-14110396
Then get like a pair of, for example. DT 990 pro with a modmic 4 uni. Paired with the SB Zx
PM/DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
HifiMan Ananda Nano, HE400se, X2HR
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Monitor > Samsung Odyssey OLED G9
Keyboard > Keychron Q3 HE TKL
Mouse > Logitech G Pro 2 Lightspeed
Mousepad > X-Gamer XG++ XXL mousepad
Read this post if you want a "gaming" headset ;)
https://linustechtips.com/topic/1256901-sound-cards/#findComment-14110397
I do wear glasses tho. It has foam where the arms of the glasses would be.
https://linustechtips.com/topic/1256901-sound-cards/#findComment-14110400
