A couple of days ago i bought a GTX 1080 TI ROG STRIX and when i first installed it , it was wonderful 180+FPS on Warzone. A day passed and i noticed that my PSU couldnt handle both my GPU and CPU so i changed it for a new more capable one. Since that specific day the GPU hasnt been the same , it now performs 90 to 120 FPS and sometimes more but it doesnt run as it first did. I have a Ryzen 5 2600 CPU and i know it is not the best one for the job but it was doing great the first day. Now im worried , i even fresh installed windows and nothing. The CPU is clocked at 3.9 and my RAM at 3266 with double channel active. Im really frustrated with this. I noticed that the GPU updated itself to some newer drivers available no more than 2 days ago , it could be that?spacer.pngspacer.pngspacer.pngspacer.pngspacer.pngspacer.png
https://linustechtips.com/topic/1256282-gtx-1080-ti-performance-problems/
My question is how long have you been playing warzone?only curious because some cod updates have in my opinion bogged down some fps ,what resolution you using ,is everything maxxed out?
I have 1080ti  gigabyte extreme  version owned for 4 years only owner tbut it's watercooled with g12 bracket.The cpu I paired with it is 10900k , however I was using a 8700k and I still got over 170fps  in 1080p sometimes even with ray tracing on , 4k usually averaging around 85fps.make sure in Nvidia panel lod is set to allow not clamp ,force mutli thread on ,make sure it's in high performance ,turn off the filtering options ,make sure the gpu profile is set to 1080 ti,make sure physx option is set to 1080ti not cpu .i use precision x16, Id assume your using msi afterburner. try a slight and I mean a slight voltage increase after a decent mem overclock .my cards sits at 2038mhz or core clock and 5613 on mem.when I have had issues in past with frames I would overclock the gpu slightly by slightly I mean 2076mhz core clock and 5800mhz mem clock keep in mind I have alot of headroom because it's watercooled .maybe a really slight overclock on mem.the card might be throttling though,also do a disk clean up admin though,you would be surprised how that copied delivery optimaztions can be in the 2gb range of data ,would suggest driver booster and advance system care for overall system performance,hope I helped
My current build is 10900k gigabyte z 490 vison d 1080ti    32gb of ram 1300 watt psu
Intel 665 m.2 nvme1tb
Samsung 960pro m.2 name 1tb
Samsung 850 1tb
Samsung 850 500gb
Samsung 850 1tb
Samsung 850 500gb
I have played since day one. Didnt have the hardware i have now but the fps were from anywhere to 100-120 with an RX580. Im gonna try everything you said. Thanks.
PS: Some DSR setting keeps changing on the Control Panel wihout me noticing. Should i be worried?
Just set the settings you told me to , except the OC and im getting some weird spikes.  From 90 to 150 , im assuming its the CPU. Im just going to wait for the new Ryzen line up. Thanks.
Dsr does do that sometimes,usually a indication the driver is faulty.
