"system" using 99% gpu usage while playing Minecraft
Go to solution Solved by Yea, i use windows, W,
1 minute ago, peepoo said:
yeah it is the RX 5600 XT
I did. no difference, stayed at a 5-10 fps range
Welp, this also may be a software issue or a virus attack, or maybe a minecraft glitch, the best thing which SOLVES ALL PROBLEMS (Most) IS to restart your computer, make sure your %temp% folder is clear, if that doesnt solve it (Which i guess makes sense), You have to go the BIG way, backup only the necessary things, Install windows again, and it will probably fix the issue, if it still doesn't (Which is impossible) Then im out of solutions
Task manager shows 'system' going to 99% usage when playing Minecraft
I think its some sort of virus but idk how to get rid of it
It starts as soon as I load up a Minecraft world
Soon as I quit Minecraft, it goes back down to appropriate idle usage
What graphics do you have?
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
Is that your RX 5600 XT? You might have no framerate limiter so the GPU tries its hardest to paint as many frames per second as possible. Try to limit fps in the game settings to your monitor's refresh.
Computer Specs:
How do you know? about his GPU? just curious
YES, I RUN RAID 1 OVER RAID 0
REMEBER TO QUOTE 😜
His previous thread 😛
Computer Specs:
REMEBER TO QUOTE 😜
I'm literally have the EXACT same problem. I think we both have 5600XTs and I was wondering if you have figured out what was wrong yet.
sorry for late response, I have marked the solution but will summarise it in 1 sentence, reinstall windows.
I think its a virus that came with a program that you've downloaded.
From what I can understand, the virus 'latches' onto a vital part windows 10 (in this case, "system"), so that it can hide with system processes, and when an application is loaded (I have no idea why its specifically Minecraft) the virus 'activates' and starts using the graphics card to start mining for digital currency or something of the sort.
Inform me if my explanation is wrong because this is all inference.
That seemed to fix it for me, thanks!
  • 5 months later...
