I NEED HELP
Go to solution Solved by Tanaz,
Just now, Zababoh said:
Oh.I mean I could wait but I just want the best gpu for my cpu which I thought was the 3070
3070 will be bottlenecked at 1080p. Get it if you're going to buy a 1440p monitor. If not you can wait for the 3060 and save yourself some money.
CAN ANYONE HELP ME OUT?
so this is my first time building a pc and I don’t know what graphics card to buy the part I bought so far is
  1. AMD Ryzen 5 3600
  2. Asus Tuf Motherboard with WiFi
  3. 32 Gigs of Vengeance Ram
  4. G-skill 750 Modular Power Supply
  5. 512 Gig m.2 drive
  6. NZXT H510 Case
WHAT GRAPHICS CARD SHOULD I BUY?
https://linustechtips.com/topic/1255973-i-need-help/
What resolution and what refresh rate are you playing at? What is your budget? A bit too general to get a good answer.
Ada is worse than Ampere which is worse than Fermi, change my mind.
System:
  • CPU
    AMD Ryzen 9 5950x
  • Motherboard
    ASUS X570 TUF
  • RAM
    2X16GB Kingston Fury 3200mhz
  • GPU
    Gigabyte RTX 4080 Super Gaming OC
  • Case
    Fractal Torrent
  • Storage
    A lot of SSDs
  • PSU
    Seasonic 1000W Platinum
  • Display(s)
    Main: ASUS PG27AQDM 240hz 1440p WOLED
    Secondary: Alienware AW2521HF 1080p 240hz
    Third: Samsung C34F791 UltraWide 1440p 100hz
    Fourth: LG 48' C2 OLED TV
  • Cooling
    Noctua NH-D15
  • Keyboard
    Ducky Shine 7
  • Mouse
    GPX Superlight
  • Sound
    Logitech Z906 / Sennheiser 560s / Rode NT-USB
  • Operating System
    Windows 11 Pro
https://linustechtips.com/topic/1255973-i-need-help/#findComment-14102369
Depends on your budget, you can go with any card  you like actually.
https://linustechtips.com/topic/1255973-i-need-help/#findComment-14102374
I haven’t even played because I turned it on and it’s a black screen. But the res I would like is 1440p or 1080p at 144hz. My budget for the you is about 500
https://linustechtips.com/topic/1255973-i-need-help/#findComment-14102384
Used 2080ti or wait for the rtx 3070
14700k
Thermalright frozen prism 360mm aio
B760 Aorus elite ax ddr5
32gb ddr5 G skill s5 6000mhz CL30
2tb wd black gen 4 nvme
2tb Solidigm P41 plus
2tb seagate hdd
Pny 5070ti
Fractal Ion 2+ 860watt platinum
Thermaltake View 380
AW2725DF 1440p 360hz oled
Aoc Q27G3XMN mini led
Ps5 Pro
Series X
https://linustechtips.com/topic/1255973-i-need-help/#findComment-14102395
1080p 144hz cards - RTX 2060 Super, 2070 Super or 5700/5700XT or RTX 3070 provided you would wait for it to be available. I wouldn't go any higher especially considering the fact that your CPU would be bottlenecking fast cards at 1080p
1440p 144hz - 2070 Super/2080 Super / 5700XT or again RTX 3070 if you want to wait.
You've picked the worst time to buy a GPU as Big Navi is coming out on the 28th and Nvidia is going to drop prices of older cards when their new ones become wildly available.
If you had to buy today I'd get a 2060 Super and a 1080p 144hz monitor for a more budget oriented build. 1440p 144hz requires quite a bit more GPU power.
System:
  • CPU
    AMD Ryzen 9 5950x
  • Motherboard
    ASUS X570 TUF
  • RAM
  • GPU
  • Case
    Fractal Torrent
  • Storage
    A lot of SSDs
  • PSU
  • Display(s)
  • Cooling
    Noctua NH-D15
  • Keyboard
    Ducky Shine 7
  • Mouse
    GPX Superlight
  • Sound
  • Operating System
    Windows 11 Pro
https://linustechtips.com/topic/1255973-i-need-help/#findComment-14102397
What do you mean worst time to buy a GPU? Isn’t companies making new better for me?
https://linustechtips.com/topic/1255973-i-need-help/#findComment-14102415
Yes but you would have to wait until mid November. You didn't specify when you're buying the GPU.
System:
  • CPU
    AMD Ryzen 9 5950x
  • Motherboard
    ASUS X570 TUF
  • RAM
  • GPU
  • Case
    Fractal Torrent
  • Storage
    A lot of SSDs
  • PSU
  • Display(s)
  • Cooling
    Noctua NH-D15
  • Keyboard
    Ducky Shine 7
  • Mouse
    GPX Superlight
  • Sound
  • Operating System
    Windows 11 Pro
https://linustechtips.com/topic/1255973-i-need-help/#findComment-14102423
System:
  • CPU
    AMD Ryzen 9 5950x
  • Motherboard
    ASUS X570 TUF
  • RAM
  • GPU
  • Case
    Fractal Torrent
  • Storage
    A lot of SSDs
  • PSU
  • Display(s)
  • Cooling
    Noctua NH-D15
  • Keyboard
    Ducky Shine 7
  • Mouse
    GPX Superlight
  • Sound
  • Operating System
    Windows 11 Pro
https://linustechtips.com/topic/1255973-i-need-help/#findComment-14102436
