Hi guys, I have recently build a pc and I have notice my internet speeds are very slow (3mbps download) on my PS4 I used to get around 35. I use a power line adapter, because that is the only way for me to use Ethernet in my house.
the power line adapter is the:
TPlink 1000mbps power line adapter.
any suggestions!!!
https://linustechtips.com/topic/1255273-help/
Did you move the PS4 ? Did you add a surge protector / power bar to the circuit to plug your PC and PS4 on the same outlet?
https://linustechtips.com/topic/1255273-help/#findComment-14095727
