Budget (including currency): $400 USD
Country:
Games, programs or workloads that it will be used for: Tf2 minecraft
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Gt 710, Wireless card(wifi card i need wireless wifi), 4x4gb Ddr3, i5 3470 Ssd, Hard drive i have been using a dell optiplex 7010 sff and i want to be able to upgrade down the line so no dell opiplex or prebuilts plz.
i want to be able to play tf2 with about 150 fps on low i currently can only get 100fps
Edited by Nathan_2510
More info
https://linustechtips.com/topic/1254484-help/
Not sure why you want even higher framerates, 100fps is already more than enough, especially since I doubt you have a 144Hz monitor...regardless, I'd try to find a used i7 and used 580 or similar. Total should run you about $150-175.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1254484-help/#findComment-14088236
I have a 175 hz monitor coming.
https://linustechtips.com/topic/1254484-help/#findComment-14088244
3 minutes ago, Nathan_2510 said:
prebuilts plz.
prebuilts are upgrade able, as long as its not a dell. they have a habbit of having standard ram,, but with a bios lock, so only dell ram works.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1254484-help/#findComment-14088246
I'd still try to find a used i7 and 580. Cheap upgrade but you'll get a lot more GPU performance and a fair amount more CPU performance.
Either that, or save up 2-3x what you have now and get brand new system.
SPECS:
https://linustechtips.com/topic/1254484-help/#findComment-14088253
My case can only fit a gt 710 and a wireless card so no dual slot gpus also i want to get new stuff so it will be easyer to upgrade down the line but i have a dell otpiplex 7010 Small Factory Form
https://linustechtips.com/topic/1254484-help/#findComment-14088272
You aren't going to get a good, brand-new system for your budget. Save up more.
SPECS:
https://linustechtips.com/topic/1254484-help/#findComment-14088292
