RTX 3080 power limits
Solved by .Apex.,
24 minutes ago, Islam Ghunym said:if anyone got his hands on the RTX 3080. what are the minimum and maximum power limits of the GPU? is it like previous generations from 50%. I heard some rumors saying that you may limit the GPU from 320W to 100W only.
https://www.techpowerup.com/vgabios/224962/nvidia-rtx3080-10240-200816
The Founders Edition BIOS goes down to 31%, so that would be 100W
