Hello guys I have two GPUS. The MSI GTX 970 OC and the Founders Edition 970. I stressed tested them both with the same variables and the MSI card hits 74C and the founders edition hits 81. I understand that the MSI has two fans which in return will keep it cooler. But what can I do for my founders edition, should I change the thermal paste ? Its pretty old but would that yield better results ? Or maybe the 970 is fine at 81 degrees. Let me know what you think. Thanks !!!
https://linustechtips.com/topic/1254043-gtx-970-temps/
81 degrees under a stress test is normal and totally fine. Play some demanding games and see what your max temps are over an hour or so and if it stays under 81C it’s just fine. Most GPUs can handle slightly higher temps than 81C for short term just not sustained over a long period.
I wouldn’t worry about 81C in a stress test.
CPU: i7 8700K (5.1 GHz OC). AIO: EVGA CLC 280 280mmGPUEVGA XC2 Ultra 2080Ti. PSU: Corsair RM850x 850W 80+ Gold Fully Modular. MB: MSI MEG Z390 ACE. RAM: 32GB Corsair Dominator Platinum RGB (3600 MHz OC). STORAGE: 1TB Samsung 970 Evo Plus M.2 NVMe, 2TB Samsung 860 EVO, 1TB Samsung 860 Evo, 1TB Samsung 860 QVO, 2TB Firecuda 7200rpm SSHD, 1TB WD Blue. CASE: NZXT H510 Elite. FANS: Corsair LL120 RGB 120mm x4. MONITOR: MSI Optix MAG271CQR 2560x1440 144hz. Headset: Steelseries Arctis 5 Gaming Headset. Keyboard: Razer Cynosa Chroma. Mouse: Razer Basilisk Ultimate (Wireless) Webcam: Logitech C922x Pro Stream Webcam.
https://linustechtips.com/topic/1254043-gtx-970-temps/#findComment-14084423
I have on Pub G it can reach 85 degrees, thats without a overclock. But if I want to overclock could changing the thermal paste help ?
https://linustechtips.com/topic/1254043-gtx-970-temps/#findComment-14084432
It could help. When is the last time you changed it?
https://linustechtips.com/topic/1254043-gtx-970-temps/#findComment-14084444
