I need help at Volt
2 hours ago, Cyracus said:I went from throttling down from 4ghz to 3700mhz at 87C+ to over 4.1ghz staying under 80C doing the same things.
The tool I linked above achieved similar results as I did on my own, took maybe an hour. The cinebench bit can be skipped if you just want the performance increase without caring about how it's x% better than stock. There's a guide on usage included in the link as well, as noted read it.The idiot's guide for idiots I needed (not a replacement for their guide obviously):
1. Reset bios, apply recommended settings listed on download page
2. Start only CTR. click diagnostic button. Tests will run for a while3. It gives you two results, OC and undervolt, choose your preference
4. input numbers chosen and click start
5. Other tests will run, when finished will tell you results
6. Click create and apply profile, make sure autoload with OS is enabled.
Hey thanks for such info but , 1.4v+ is fine for 3rd gen and idk why are keep saying abt overclock and all , i use my pc on my base clock 3.86ghz but now AMD_Robert said 1.4 is good for cpu dw abt tht bcz 3700x + cpus take that much load and only cpuz shows the real thing rest gives boost and shows kinda fake!
