Problems with my Ethernet (Mac OS)
Hello, as the title says I'm having problems with my Ethernet Connection, I've read that there was a problem with an update that literally killed the ethernet cable.
The strange thing is that in my Bootcamp partition the Ethernet cable works just fine, does someone know how to fix it?
It says:
Status: Not connected
The Ethernet cable is connected, but the computer has no IP address assigned.
Please help, I'm trying to sell my iMac and I need it to work well;
Special Info: my iMac is from 2017, 27' 5k retina and I'm on Catalina 10.15.5
(the photo is in spanish)
Did you try restarting your Router? And you switch if you have one in between...
I tried but nothing happened, and sadly my router only has one. It's like a repeater
I would know how to fix it in windows but i am sorry ive never owned a macbook so i cant help you more...
It looks like you've deactivated the ethernet port. What does it look like when you expand the menu? It should look something like this
  • 3 weeks later...
Yes!
That was the problem, very stupid indeed. Thank you anyway
