Help please! I recently got a 3080, replacing my 1070 however in games im getting much worse performance than I was on my 1070! COD warzone is now sub 80fps (before over 100) and World of Warcraft is now just above 100 (was 160)
Specs are;
ASUS Strix B550
AMD 3700x
16GB Corsair 3200mhz
ASUS TUF 3080
1000w superflower power supply, two separate PCIE 8pins to the card from the PSU
1440p monitor over display port.
nothing in the system has changed other than the GPU and ive tried all sorts! Help appreciated!
https://linustechtips.com/topic/1253281-rtx-3080-performance-problems/
3 minutes ago, Gamer Schnitzel said:
download shaow of the tomb raider and run the benchmark on the highest preset and post the screenshot here. then people can help better, it's more useful than just a bunch of fps numbers
Thanks, downloading the demo now and will amend my original with the photo when done
Specs are;
ASUS Strix B550
AMD 3700x
ASUS TUF 3080
Wait, you guys are getting 3080's?
CPU-AMD Ryzen 7 7800X3D GPU- Gigabyte WindForce SFF RTX 5070ti MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE- 2TB Samsung 990 Pro PCIE4 NVME x2 PSU-Corsair RM1000x Shift COOLING-Lian Li GA II Lite 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-Samsung G61 QD-OLED 1440p 240hz +Gigabyte G24F 1080p 180hz PERIPHERALSVaxee XE-S+Padsmith Crucible Mousepad+Monsgeek M1 V5 TMR+Autonomous ErgoChair+ AUDIO-Audient iD4 Mk II + Rode NTH100
Sure, nvidia did make a few at least.
Seen a few people on here that managed to grab one, personally I managed to get both a 3080 and 3090.
Unfortunately mine needed to be shipped overseas to me, I have tracking so I know they are coming, but it takes a couple of weeks.
