After looking at task manager i have big conserns over my cpu and gpu.
For some reason im struggling to get 100 fps on warzone with an rtx 2060 super..
Also my cpu is spiking whilst my gpu isnt.. HELP!! im scared if my hardware is broken or soemthing
Also my ram is using 12% when doing nopthing... ANYONE?
MY GOU IS LITERTALL:Y AT 1% pls help im new to windows and pc/...
here are some images825928788_Screenshot(18).thumb.png.22e144b7381018fc7930a16fb2146e6d.png
https://linustechtips.com/topic/1252404-help-is-somethingf-wrong/
If it was broken, you'd get BSoD or other obvious error messages.
What version of Win10 do you have and the build number?
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
when you alt tab out of the game and have task manager as the main application (focus application) the game automatically caps framerate to prevent it from using gpu/cpu power on something that's running in the background, so you can't use task manager to check that :).
secondly, your pc using 12% ram on startup with a chrome tab is perfectly normal.
your cpu spiking is because while the 2600 is a good cpu it's single core performance (which is important in games) is not the greatest in the world, (own the 2700x myself).
i see no issues with your build and parts mate.
when i go on ultra settings and 1440p + rtx i get about 120fps with my 2080, so i don't think there is anything wrong
Anything i've written between the * and * is not meant to be taken seriously.
keep in mind that helping with problems is hard if you aren't specific and detailed.
i'm also not a professional, (yet) so make sure to personally verify important information as i could be wrong.
Just now, Mr.Moustache said:
@flashiling
OMG tysm! ive been going crazy for a bit, thought my pc was broken after i month lMAo
if i may ask,
how many fps do you get when playing csgo? (ingame not in the menu).
if you own the game that is :).
Thanks i was worried for no reason then lol. But for some reason im not getting over 100 fps, i usually get over 100 in high settings but now im on 30. Anyone can help?
just calm down, nothing seems to be broken
is it 30 while playing or when you alt tab out?
it's normal for game to run at 30fps when you arent playing it
-sigh- feeling like I'm being too negative lately
@Moonzy
whist playing, i just tried at 720p and its 30 :/
try running it at 1080p, low preset in graphics settings
if you're unsure, post screenshots here
and make sure nothing demanding (like another game) is running in the background
1 minute ago, Mr.Moustache said:
@flashiling
i get around 200 something
crap i only get 120-140 with a 2080
maybe it's my system that's broken :D
@flashiling
@Moonzy
IM so fu$%^ dumb, i had v sync on.......
though it still dosent answer why my ping is at 300 whilst i usually get aroiund 60...
Sorry for all that trouble
ping could be related to your network speed being poor, or just the server location/server load on the game you play.
this is 9 out of 10 times something on the ISP side, so you cant do anything
what's your connection like? wifi? or LAN cable directly into router? any extender or anything of the sort?
