external monitor from laptop
SnowyLynx-_-
Hi ok so would it be bad for gaming if you connect a laptop to a external monitor in my case the game would be fortnite
Specs of laptop? Specs of external monitor?
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
the laptop has Ryzen 7 4800H RTX 2060 and 16gb ram 144hz screen the monitor is 60hz 1080p
Well for starters you'll be limited to only 60 FPS max on that monitor. Any FPS above that is not being displayed.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 17.2.1) | iPhone XR (iOS 17.2.1) | iPad Mini (iOS 9.3.5) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
Why would you not want to use the 144hz one for a game like fortnite?
Bios database
prior build:
Just now, BlueChinchillaEatingDorito said:
Well for starters you'll be limited to only 60 FPS on that monitor.
im mostly going for FPS not smoothness of it or anything
Well then you would want to stick to the built in display then.
thats what im saying i dont mind the smoothness or the hertz im just looking for latency and input delay
there will be less latency/input delay on the 144hz one because of how it works. with a 60hz display a input will have not be seen on screen for 1/60th of a second. For 144hz, its 1/144th of a second
Bios database
prior build:
oh ok thanks i didnt know that
