So I have had my gaming laptop for around 2 years and recently I have been having an issue when running games where the computer keeps switching to battery power, it does this switching for up to 10 seconds then stops, but does it around every 3 mins. Sometimes when it does it too much the laptop just fully switches it off. I have contacted the manufacturer (metabox) and they said that under their warranty they would ship me a new charger. Will this fix the issue?
https://linustechtips.com/topic/1250245-help/
It probably is the charger yes. Also just in general dust it out to make sure it isn't due to heat issues that it's switching off the charging circuit.
https://linustechtips.com/topic/1250245-help/#findComment-14049824
19 minutes ago, Vader11598y8y89 said:
This issue only happens when I am in intensive situations in games
probably charger issue, it cant supply enough power to the laptop when it's fully loaded (shouldn't happen)
have had that happen to my asus laptop when i used a 60W charger to replace my 120W for half a day, charger kept connecting and disconnecting when under load, idle it's fine
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1250245-help/#findComment-14049878
i use the charger they gave me so maybe the charger has just degraded over time???
https://linustechtips.com/topic/1250245-help/#findComment-14050857
perhaps, but normally they would give you one with a ton of headroom
just use the new charger, see if it's still a problem
if not, let them know
https://linustechtips.com/topic/1250245-help/#findComment-14050880
