Help understanding G Sync...
Go to solution Solved by Oshino Shinobu,
The G-Sync module doesn't increase the refresh rate of the monitor or the response time. That's all based on the actual panel. So far, there's only one or two supported monitors (I think) for G-Sync, and it's likely that you'll have to buy a G-Sync compatible monitor, rather than it being able to be used on every monitor.
If I buy one of these monitors will I eventually be able to add Gsync to them to get the refresh rate higher than 60hz as well as drop the gtg from 5ms to 1ms?
http://www.amazon.com/BenQ-Professional-BL2710PT-27-Inch-LED-lit/dp/B00D7IG5N8
http://www.amazon.com/PB278Q-27-Inch-LED-lit-Professional-Graphics/dp/B009C3M7H0/
Case: NZXT H500i. Motherboard: Asus Prime Z390-A. CPU: i7 9700k OC @ 5.0GHz. GPU: EVGA 2080 FTW3 CPU Cooler: NZXT X62. Memory: G. Skill Ripjaws 32Gb 3200mhz. Storage: 1TB Samsung 840 EVO SSD /  120GB Samsung 840 EVO SSD  /  WD Caviar Black 3TB / WD Caviar Green 4TB. . PSU: Corsair AX760. Monitor: 2x Acer XB270HU. Keyboard: Corsair K70 RGB. Mouse: Corsair Glaive.
https://linustechtips.com/topic/125001-help-understanding-g-sync/
Ehm. I'm pretty sure that 60hz monitors will be able to be upped to whatever frames you've got. (I might be wrong)
As of yet all i've heard is the 120hz monitors having G-Sync and it won't be that easy to fix yourself.
If i we're you i would just buy a G-sync screen instead of planning ahead to do it on a screen that Nvidia haven't mentioned.
Intel i7-2600K @ 4,5GHz | EVGA GeForce GTX 780 w/EKWB Copper Waterblock | Kingston HyperX blu 16GB @ 1600 MHz | Phanteks Enthoo Primo | MSI Z77A-GD65 | CM M1000 Silent Pro | Samsung 840 Pro 128GB | BenQ XL2420T 120hz | Logitech G710+ | Razer Deathadder 2013 -
- XSPC Raystorm CPU Waterblock | XSPC RX360 Radiator | EKWB EK-FC Titan GPU Waterblock -
I'm pretty sure the only monitor that you'll be able to upgrade is the Asus 144Hz one.
Otherwise, there will be monitors that have GSync already installed, and you'll be able to purchase those.
Intel i5 6600k~Asus Maximus VIII Hero~G.Skill Ripjaws 4 Series 8GB DDR4-3200 CL-16~Sapphire Radeon R9 Fury Tri-X~Phanteks Enthoo Pro M~Sandisk Extreme Pro 480GB~SeaSonic Snow Silent 750~BenQ XL2730Z QHD 144Hz FreeSync~Cooler Master Seidon 240M~Varmilo VA87M (Cherry MX Brown)~Corsair Vengeance M95~Oppo PM-3~Windows 10 Pro~http://pcpartpicker.com/p/ynmBnQ
