Budget (including currency): 1700
Country: USA
Games, programs or workloads that it will be used for: Blender, SoT, Call of duty, forza, NFS, WoW, Little bit of everything.
This is currently what I am looking at. I do not have a lot of room to do a massive build so i would like to build a MicroATX. However I have never built one and would like some assistance in making sure this will be good.  I am not to sure about that GPU and CPU. I have generally ran AMD everything but I am wanting to build an Intel machine. Thanks for any help.
https://linustechtips.com/topic/1249413-small-footprint-build/
9th gen intel is already superseeded, you're also getting a K processor on an non-overclocking board.
i would go with a i5-10600k if you want intel, it performs better in games than the 9900k.
also get a z490 motherboard for it.
and wait for the rtx 3070 release. it will be much better than the 5700xt.
https://linustechtips.com/topic/1249413-small-footprint-build/#findComment-14042660
10 hours ago, Pkreifels said:
Would it actually be better to run 64GB single channel over dual channel?
1x64 would be single channel
2x32 is dual channel and is recommended.
4x16 would run in dual channel as well,as quad channel is not supported by this platform.
https://linustechtips.com/topic/1249413-small-footprint-build/#findComment-14049613
Okay thank you for your help.
https://linustechtips.com/topic/1249413-small-footprint-build/#findComment-14051577
