6 hours ago, Maury Sells Wigs said:
My ps4 made that noise for ages.
It's just the fan, so nothing to worry about.
Better it works as intended than not at all, right?
Cleaned it its fine now also does ypur ps4 get hot at the middle end part pf the plastic where psu is located
https://linustechtips.com/topic/1249310-ps4-fan/#findComment-14048589
It will get hot, yes.
I took my old release day ps4 apart last year, and the amount of gunge and dust was incredible.
Fair play though, I got it on release day in 2013, and my brother now has it (after I got a pro last summer), yet it still works fine with no issues at all.
Yes, it can get a bit noisy on certain demanding games as the fan cranks up to full speed.
But, better that than it doesn't work and melts the system.
https://linustechtips.com/topic/1249310-ps4-fan/#findComment-14049129
Is it fan buzzing or coil whine? They're completely different
https://linustechtips.com/topic/1249310-ps4-fan/#findComment-14058466
1 minute ago, Bad5ector said:
@Slottr Jinx you owe me a beer.
If for some reason we ever bump into each other, you can hold me to that
https://linustechtips.com/topic/1249310-ps4-fan/#findComment-14058481
11 minutes ago, Fzonea said:
Dont get me wrong fan is spinning normally
VID_20200925_204442.3gp
Couldn't hear anything from that, sorry.
https://linustechtips.com/topic/1249310-ps4-fan/#findComment-14058628
https://www.youtube.com/watch?v=xbtyMHd9HOE&app=desktop just like this video but i have slim and its lot of quieter then on the video i literally need to stuck my ear on where is fan to hear it.
https://linustechtips.com/topic/1249310-ps4-fan/#findComment-14058774
That fluttering sound?
https://linustechtips.com/topic/1249310-ps4-fan/#findComment-14058779
Just now, Fzonea said:
Yea somethong like it but i need to get real close to hear it
Could be anything really. Fan, bearing, disc drive, hard drive... Can't really do anything till you rip it open
https://linustechtips.com/topic/1249310-ps4-fan/#findComment-14058789
Its coming from the fan i opened the top case and heared it. Its probably plastic or something. Fan is clear i cleaned it 2 days ago
https://linustechtips.com/topic/1249310-ps4-fan/#findComment-14058794
