What are the temps? Try switching Windows to performance mode and look into task manager to check the CPU frequency after that.
CPU: Intel Core i7 8086K, Delidded with Der8auer Custom Nickel-Copper IHS and Coollaboratory Liquid Ultra聽CPUCooling: Scythe Ninja 5 with Thermal Grizzly Kryonaut Thermal Paste聽Motherboard: ASRock Z370 Taichi RAM: 2x16GB Kingston Predator DDR4 3200 MHz 15-17-17-36 GPU: Gainward RTX 2080 Phoenix GS with聽Raijintek聽Morpheus II Core Black Heatpipe VGA Cooler, Thermal Grizzly Kryonaut Thermal Paste and 2x Scythe Kaze Flex PWM聽120mm fans聽Case: SilentiumPC Regnum RG4T Pure Black TG Storage: Samsung 960 EVO 250GB, Samsung 970 EVO 500GB, Seagate ST4000DM 4TB HDD, Toshiba HDWD240 4TB HDD PSU: SilentiumPC Supremo FM2 Gold 750W聽CaseCooling: 6x Scythe Kaze Flex PWM聽120mm fans Keyboard: Corsair Strafe Mechanical Keyboard Mouse: Trust GXT845 Tural Display: Sharp LC-50LD265E聽Operating System:Windows 10
https://linustechtips.com/topic/1249137-i-need-help-plz/#findComment-14040616
The temps are well under 50聽degrees at load and I have tried everything including switching to performance mode and changing to windows 7 as well but got nothing
https://linustechtips.com/topic/1249137-i-need-help-plz/#findComment-14040627
Which Core 2 Duo do you have?
https://linustechtips.com/topic/1249137-i-need-help-plz/#findComment-14040628
10 minutes ago, Karan Chopra said:
I have a pc with a core 2 duo which is supposed to run at 1.8ghz but the base clock shows only 0.9ghz and it also runs at that speed only. Pls help 馃槶
What are you using to verify clockspeed? If you're just using Task Manager then that's most likely the problem as that is terrible at showing correct information. Use a program like CPU-Z and run a benchmark like Cinebench R15 and see what the clockspeed shows in CPU-Z while the benchmark is running.
https://linustechtips.com/topic/1249137-i-need-help-plz/#findComment-14040637
I have tried that too but it also shows the same
https://linustechtips.com/topic/1249137-i-need-help-plz/#findComment-14040646
I m using Core 2 Duo 6320 @1.86ghz
Run Cinebench R15 and show us a screenshot of your CPU frequency.
https://linustechtips.com/topic/1249137-i-need-help-plz/#findComment-14040649
Was it while the CPU was under load or while it was idle at the desktop? CPUs these days will only turbo up to their specified clockspeed once a load is applied to them.
https://linustechtips.com/topic/1249137-i-need-help-plz/#findComment-14040652
The CPU was under load as I was benching it with cinebench r20
https://linustechtips.com/topic/1249137-i-need-help-plz/#findComment-14040658
Core 2 Duos have features called聽EIST "Enhanced Intel Speed Step technology" or聽Enhanced Halt State (C1E). Try to find it in BIOS and disable it.
https://linustechtips.com/topic/1249137-i-need-help-plz/#findComment-14040660
I have searched for it but there's nothing like that in bios
Search again, maybe it has another name in your BIOS. Try to find power saving features聽and disable them.
https://linustechtips.com/topic/1249137-i-need-help-plz/#findComment-14040673
