Ideally you should be running two separate cables from the PSU.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
I'm not sure it actually matters as if the PSU manufacturer has put 2x 8pin on a single cable then that cable must be rated to 300W.  (assuming its a good brand/model PSU that is, I wouldn't trust a cheapo)
Running two cables is more a "just to be on the safe side" scenario.
I'm running a Corsair rm750x so the cable are pretty good, but I think the asus tuf 3080 is rated at 340w not 300 (not sure if this makes a difference).
Depends on the PSU provider. A few stipulate this because they only use 16AWG wire on the 6+2 pins.
[ P R O J E C T _ M E L L I F E R A ]
[ 5900X @4.7GHz PBO2 | X570S Aorus Pro | 32GB GSkill Trident Z 3600MHz CL16 | EK-Quantum Reflection ]
[ ASUS RTX4080 TUF OC @3000MHz | O11D-XL | HardwareLabs GTS and GTX 360mm | XSPC D5 SATA ]
[ TechN / Phanteks G40 Blocks | Corsair AX750 | ROG Swift PG279Q | Q-Acoustics 2010i | Sabaj A4 ]
P R O J E C T | S A N D W A S P
6900K | RTX2080 | 32GB DDR4-3000 | Custom Loop
You mean 18AWG?
Most PSUs use 18AWG wiring afaik.
9 hours ago, Mateyyy said:
You mean 18AWG?
Yes 16. I'd point to stuff like the Corsair AX series that give no advice in their manuals about using separate cables for 6-2 pins versus EVGA from memory and a couple of others who do.
I know people have tested and two separate cables offer marginally better power delivery but the practical benefits unless you're on the absolute ragged edge are zero.
